最小化安装cuda runtime 失败
hello,英伟达各位专家们,我现在想最小化安装cuda runtime 请教下怎么操作,目前我是采用的basic的rootfs+命令行安装的,但是jtop看到并没有安装完cuda和opencv这些,单独安装也没有报错但jtop仍不可显示,麻烦指导一下,非常感谢。
安装用的这个命令行:
sudo apt-get install nvidia-cuda nvidia-tensorrt nvidia-cudnn8 nvidia-cupva nvidia-opencv nvidia-container nvidia-vpi
log.txt (46.2 KB)
单独安装完opencv也显示未安装,VPI和cuDNN jtop可以显示出来,所以是什么问题呢?
log.txt (24.2 KB)
Please check if you can see the installed package with dpkg -l command:
$ dpkg -l | grep cuda
$ dpkg -l | grep opencv
log1.txt (3.8 KB)
Hello,AastaLLL , 这是我板子上输出的结果,麻烦帮忙看看~~thank you very much
It looks like CUDA and OpenCV are installed in your environment.
Please check the following issue in the below topic:
