CUDA SDK compilation error on Fedora 11
Ok, here is what I did
  1. Update the kernel (the older one seemed to be broken).
[vivek@farpoint ~]$ uname -r
2.6.29.6-217.2.16.fc11.i686.PAE
Then, I installed libXi and libXmu:
yum install libXi* libXmu*
Then, I got hold of the cuda driver (cudadriver_2.3_linux_32_190.18.run) and installed it ON the existing nvidia-x11-drv-190.18-1.fc11.i686. This time, it didn’t give me a “could not load kernel module nvidia.ko” error like it used to earlier. I think this has to do with the older broken kernel (correct me if I’m wrong).
Next, I followed [post=“0”]highman’s instructions[/post]:
Then I ran make:
[root@farpoint NVIDIA_GPU_Computing_SDK]# cd C
[root@farpoint C]# make
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/common'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/common'
make -C src/MonteCarloMultiGPU/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/MonteCarloMultiGPU'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/MonteCarloMultiGPU'
make -C src/asyncAPI/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/asyncAPI'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/asyncAPI'
make -C src/simpleGL/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleGL'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleGL'
make -C src/dwtHaar1D/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/dwtHaar1D'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/dwtHaar1D'
make -C src/eigenvalues/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/eigenvalues'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/eigenvalues'
make -C src/SobolQRNG/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/SobolQRNG'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/SobolQRNG'
make -C src/simpleVoteIntrinsics/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleVoteIntrinsics'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleVoteIntrinsics'
make -C src/matrixMulDynlinkJIT/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/matrixMulDynlinkJIT'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/matrixMulDynlinkJIT'
make -C src/simpleCUFFT/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleCUFFT'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleCUFFT'
make -C src/MersenneTwister/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/MersenneTwister'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/MersenneTwister'
make -C src/transpose/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/transpose'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/transpose'
make -C src/sortingNetworks/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/sortingNetworks'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/sortingNetworks'
make -C src/recursiveGaussian/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/recursiveGaussian'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/recursiveGaussian'
make -C src/fastWalshTransform/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/fastWalshTransform'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/fastWalshTransform'
make -C src/convolutionFFT2D/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/convolutionFFT2D'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/convolutionFFT2D'
make -C src/bandwidthTest/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/bandwidthTest'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/bandwidthTest'
make -C src/matrixMul/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/matrixMul'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/matrixMul'
make -C src/deviceQueryDrv/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/deviceQueryDrv'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/deviceQueryDrv'
make -C src/quasirandomGenerator/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/quasirandomGenerator'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/quasirandomGenerator'
make -C src/scalarProd/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/scalarProd'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/scalarProd'
make -C src/scan/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/scan'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/scan'
make -C src/particles/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/particles'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/particles'
make -C src/fluidsGL/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/fluidsGL'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/fluidsGL'
make -C src/simpleStreams/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleStreams'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleStreams'
make -C src/clock/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/clock'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/clock'
make -C src/imageDenoising/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/imageDenoising'
imageDenoisingGL.cpp:46: warning: deprecated conversion from string constant to ‘char*’
imageDenoisingGL.cpp:54: warning: deprecated conversion from string constant to ‘char*’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/imageDenoising'
make -C src/alignedTypes/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/alignedTypes'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/alignedTypes'
make -C src/dxtc/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/dxtc'
./dxtc.cu(101): Advisory: Loop was not unrolled, unexpected control flow construct
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/dxtc'
make -C src/simpleTemplates/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTemplates'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTemplates'
make -C src/BlackScholes/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/BlackScholes'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/BlackScholes'
make -C src/smokeParticles/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/smokeParticles'
particleDemo.cpp: In function ‘int main(int, char**)’:
particleDemo.cpp:844: warning: deprecated conversion from string constant to ‘char*’
particleDemo.cpp:845: warning: deprecated conversion from string constant to ‘char*’
ParticleSystem.cpp: In member function ‘void ParticleSystem::sphereEmitter(uint&, nv::vec3f, nv::vec3f, nv::vec3f, float, int, float, float)’:
ParticleSystem.cpp:322: warning: unused variable ‘dist’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/smokeParticles'
make -C src/cppIntegration/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/cppIntegration'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/cppIntegration'
make -C src/oceanFFT/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/oceanFFT'
oceanFFT.cpp: In function ‘void runCudaTest(bool)’:
oceanFFT.cpp:460: warning: deprecated conversion from string constant to ‘char*’
oceanFFT.cpp:472: warning: deprecated conversion from string constant to ‘char*’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/oceanFFT'
make -C src/simpleAtomicIntrinsics/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleAtomicIntrinsics'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleAtomicIntrinsics'
make -C src/postProcessGL/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/postProcessGL'
ptxas /tmp/tmpxft_0000142c_00000000-2_postProcessGL.ptx, line 330; warning : Double is not supported. Demoting to float
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/postProcessGL'
make -C src/simpleTexture/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTexture'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTexture'
make -C src/boxFilter/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/boxFilter'
boxFilter.cpp:48: warning: deprecated conversion from string constant to ‘char*’
boxFilter.cpp:69: warning: deprecated conversion from string constant to ‘char*’
boxFilter.cpp:515: warning: unused parameter ‘argc’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/boxFilter'
make -C src/simpleCUBLAS/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleCUBLAS'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleCUBLAS'
make -C src/simpleZeroCopy/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleZeroCopy'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleZeroCopy'
make -C src/volumeRender/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/volumeRender'
volumeRender.cpp:61: warning: deprecated conversion from string constant to ‘char*’
volumeRender.cpp:217: warning: unused parameter ‘x’
volumeRender.cpp:217: warning: unused parameter ‘y’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/volumeRender'
make -C src/bicubicTexture/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/bicubicTexture'
bicubicTexture.cpp:88: warning: deprecated conversion from string constant to ‘char*’
bicubicTexture.cpp:118: warning: deprecated conversion from string constant to ‘char*’
bicubicTexture.cpp:685: warning: unused parameter ‘argc’
bicubicTexture.cpp:574: warning: ‘shaderCode’ defined but not used
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/bicubicTexture'
make -C src/simpleTexture3D/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTexture3D'
simpleTexture3D.cpp:190: warning: unused parameter ‘x’
simpleTexture3D.cpp:190: warning: unused parameter ‘y’
simpleTexture3D.cpp: In function ‘void runAutoTest(int, char**)’:
simpleTexture3D.cpp:316: warning: deprecated conversion from string constant to ‘char*’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTexture3D'
make -C src/threadMigration/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/threadMigration'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/threadMigration'
make -C src/convolutionSeparable/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/convolutionSeparable'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/convolutionSeparable'
make -C src/marchingCubes/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/marchingCubes'
marchingCubes.cpp:127: warning: deprecated conversion from string constant to ‘char*’
marchingCubes.cpp: In function ‘void runAutoTest(int, char**)’:
marchingCubes.cpp:317: warning: deprecated conversion from string constant to ‘char*’
marchingCubes.cpp:318: warning: deprecated conversion from string constant to ‘char*’
marchingCubes.cpp:319: warning: deprecated conversion from string constant to ‘char*’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/marchingCubes'
make -C src/binomialOptions/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/binomialOptions'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/binomialOptions'
make -C src/simpleTextureDrv/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTextureDrv'
simpleTextureDrv.cpp:37: warning: deprecated conversion from string constant to ‘char*’
simpleTextureDrv.cpp:38: warning: deprecated conversion from string constant to ‘char*’
simpleTextureDrv.cpp: In function ‘void showHelp()’:
simpleTextureDrv.cpp:64: warning: too many arguments for format
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleTextureDrv'
make -C src/dct8x8/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/dct8x8'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/dct8x8'
make -C src/convolutionTexture/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/convolutionTexture'
main.cpp: In function ‘int main(int, char**)’:
main.cpp:123: warning: comparison between signed and unsigned integer expressions
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/convolutionTexture'
make -C src/SobelFilter/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/SobelFilter'
In file included from SobelFilter.cpp:29:
SobelFilter_kernels.h:41: warning: deprecated conversion from string constant to ‘char*’
SobelFilter.cpp:46: warning: deprecated conversion from string constant to ‘char*’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/SobelFilter'
make -C src/lineOfSight/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/lineOfSight'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/lineOfSight'
make -C src/transposeNew/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/transposeNew'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/transposeNew'
make -C src/matrixMulDrv/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/matrixMulDrv'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/matrixMulDrv'
make -C src/ptxjit/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/ptxjit'
ptxjit.cpp: In function ‘int main(int, char**)’:
ptxjit.cpp:83: warning: comparison between signed and unsigned integer expressions
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/ptxjit'
make -C src/Mandelbrot/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/Mandelbrot'
Mandelbrot.cpp:155: warning: deprecated conversion from string constant to ‘char*’
Mandelbrot.cpp: In function ‘void keyboardFunc(unsigned char, int, int)’:
Mandelbrot.cpp:641: warning: deprecated conversion from string constant to ‘char*’
ptxas /tmp/tmpxft_0000194f_00000000-2_Mandelbrot_sm11.ptx, line 1788; warning : Double is not supported. Demoting to float
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/Mandelbrot'
make -C src/radixSort/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/radixSort'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/radixSort'
make -C src/nbody/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/nbody'
nbody.cpp: In function ‘void initGL()’:
nbody.cpp:233: warning: deprecated conversion from string constant to ‘char*’
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/nbody'
make -C src/simpleMultiGPU/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleMultiGPU'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simpleMultiGPU'
make -C src/MonteCarlo/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/MonteCarlo'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/MonteCarlo'
make -C src/scanLargeArray/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/scanLargeArray'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/scanLargeArray'
make -C src/reduction/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/reduction'
ptxas /tmp/tmpxft_00001bc0_00000000-2_reduction_kernel_sm10.ptx, line 8281; warning : Double is not supported. Demoting to float
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/reduction'
make -C src/histogram/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/histogram'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/histogram'
make -C src/deviceQuery/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/deviceQuery'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/deviceQuery'
make -C src/simplePitchLinearTexture/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simplePitchLinearTexture'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/simplePitchLinearTexture'
make -C src/template/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/template'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/template'
make -C src/3DFD/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/3DFD'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/3DFD'
make -C src/threadFenceReduction/
make[1]: Entering directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction'
make[1]: Leaving directory `/opt/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction'
Finished building all
PS – Should I be worried about the warnings in this compilation?
Next, as myself, I ran deviceQuery:
[vivek@farpoint release]$ ./deviceQuery
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 2 devices supporting CUDA
Device 0: "GeForce GTX 295"
  CUDA Driver Version:						   2.30
  CUDA Runtime Version:						  2.30
  CUDA Capability Major revision number:		 1
  CUDA Capability Minor revision number:		 3
  Total amount of global memory:				 938803200 bytes
  Number of multiprocessors:					 30
  Number of cores:							   240
  Total amount of constant memory:			   65536 bytes
  Total amount of shared memory per block:	   16384 bytes
  Total number of registers available per block: 16384
  Warp size:									 32
  Maximum number of threads per block:		   512
  Maximum sizes of each dimension of a block:	512 x 512 x 64
  Maximum sizes of each dimension of a grid:	 65535 x 65535 x 1
  Maximum memory pitch:						  262144 bytes
  Texture alignment:							 256 bytes
  Clock rate:									1.24 GHz
  Concurrent copy and execution:				 Yes
  Run time limit on kernels:					 Yes
  Integrated:									No
  Support host page-locked memory mapping:	   Yes
  Compute mode:								  Default (multiple host threads can use this device simultaneously)
Device 1: "GeForce GTX 295"
  Total amount of global memory:				 939261952 bytes
  Warp size:									 32
  Run time limit on kernels:					 No
  Integrated:									No
Test PASSED
Press ENTER to exit...
Yippee! Thanks a ton everyone, esp highman!
By the way, I can’t run deviceQuery as root. I get this error:
[root@farpoint release]# ./deviceQuery
./deviceQuery: error while loading shared libraries: libcudart.so.2: cannot open shared object file: No such file or directory
This isn’t a problem with the .bash_profile script, which for the superuser is the same as that for myself:
# .bash_profile
# Get the aliases and functions
if [ -f ~/.bashrc ]; then
		. ~/.bashrc
fi
# User specific environment and startup programs
PATH=$PATH:$HOME/bin
PATH=$PATH:/usr/local/cuda/bin
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib
export PATH
export LD_LIBRARY_PATH
I am wondering whether the warnings during make will have any impact on my own programs in C/CUDA. Also, why am I not able to run deviceQuery as root?
For future reference, I have documented these steps here: http://viveks.wikidot.com/cuda-in-fedora-11
I had the same problem with gcc (why is there always a problem with gcc and CUDA?), I managed to compile the SDK but then when I compiled a function of my own I got the same error again (the weak problem), so I tried to change to gcc 4.3 but now it does not work at all, I just get
gcc: installation problem, cannot exec `cc1plus’: No such file or directory
I’ve tried to reinstall gcc 4.4 but nothing works? I think I removed a soft link that I should not have removed…
I use Fedora 11
Both gcc and g++ seem to be there?
$ gcc
gcc: no input files
g++
g++: no input files
Ok, if anyone wonders, the problem seemed to be that gcc and g++ had to be the same version (??) so this should solve the problem
yum install compat-gcc-34
yum install compat-gcc-34-c++
