Hello all,
I have some problem compiling CUDA SDK sample projects after successful installation of toolkits and SDK on Ubuntu 9.04.
In ‘~/NVIDIA_CUDA_SDK’ directory, I did make to compile the sample source codes but encountered below error message while compilation:
simpleTexture3D.cpp: In function ‘void runAutoTest(int, char**)’:
simpleTexture3D.cpp:334: warning: deprecated conversion from string constant to ‘char*’
/usr/bin/ld: cannot find -lXi
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/linux/release/simpleTexture3D] error 1
make[1]: Leaving directory `/home/sjlee/NVIDIA_CUDA_SDK/projects/simpleTexture3D’
make: *** [projects/simpleTexture3D/Makefile.ph_build] error 2
and the make failed.
If anyone has an idea to solve this problem, please be kind enough to share the idea. Thank you.
