This is my first post and I am hoping a few kind souls can help me out. I have been searching the forums for a solution and I was unsuccessful. I am trying to compile SDK 3.2.16 by typing “make.”
relevant specs about my comp:
Fedora 14 64bit, cuda tool kit 3.2.16, gcc 4.5.1, NVIDIA SDK 3.2.16, and my current gpu is a GTS 250.
This is my current error code:
[root@pepper C]# pwd
/home/ummm/NVIDIA_GPU_Computing_SDK/C
[root@pepper C]# make
make[1]: Entering directory `/home/ummm/NVIDIA_GPU_Computing_SDK/C/common'
make[1]: Leaving directory `/home/ummm/NVIDIA_GPU_Computing_SDK/C/common'
make[1]: Entering directory `/home/ummm/NVIDIA_GPU_Computing_SDK/shared'
make[1]: Leaving directory `/home/ummm/NVIDIA_GPU_Computing_SDK/shared'
make -C src/FunctionPointers/
make[1]: Entering directory `/home/ummm/NVIDIA_GPU_Computing_SDK/C/src/FunctionPointers'
FunctionPointers_kernels.cu(62): error: calling a host function from a __device__/__global__ function is not allowed
2 errors detected in the compilation of "/tmp/tmpxft_00004f0a_00000000-4_FunctionPointers_kernels.cpp1.ii".
make[1]: *** [obj/x86_64/release/FunctionPointers_kernels.cu_20.o] Error 2
make[1]: Leaving directory `/home/ummm/NVIDIA_GPU_Computing_SDK/C/src/FunctionPointers'
make: *** [src/FunctionPointers/Makefile.ph_build] Error 2
I am willing to provide any other information, Any help would be much appreciated. Thank you in advance.
