So I am pretty new to this but I did search and can’t seem to find a good answer. When I try to compile the latest cuda SDK I get this error:
make[1]: Entering directory `/export/cuda-sdk4/shared'
make[1]: Leaving directory `/export/cuda-sdk4/shared'
make[1]: Entering directory `/export/cuda-sdk4/C'
make[2]: Entering directory `/export/cuda-sdk4/C/common'
make[2]: Leaving directory `/export/cuda-sdk4/C/common'
make[2]: Entering directory `/export/cuda-sdk4/shared'
make[2]: Leaving directory `/export/cuda-sdk4/shared'
make[2]: Entering directory `/export/cuda-sdk4/C/src/simpleTextureDrv'
make[2]: Leaving directory `/export/cuda-sdk4/C/src/simpleTextureDrv'
make[2]: Entering directory `/export/cuda-sdk4/C/src/asyncAPI'
nvcc fatal : Unsupported gpu architecture 'compute_30'
make[2]: *** [obj/x86_64/release/asyncAPI.cu.o] Error 255
make[2]: Leaving directory `/export/cuda-sdk4/C/src/asyncAPI'
make[1]: *** [src/asyncAPI/Makefile.ph_build] Error 2
make[1]: Leaving directory `/export/cuda-sdk4/C'
make: *** [all] Error 2
It’s really confusing me and I wonder if anyone here has any ideas? Is the card I have no longer supported?
The Cuda tool kit I am using is 4.2.9 and here is the card info:
| NVIDIA-SMI 3.295.49 Driver Version: 295.49 |
| Nb. Name | Bus Id Disp. | Volatile ECC SB / DB |
| Fan Temp Power Usage /Cap | Memory Usage | GPU Util. Compute M. |
| 0. Tesla C2050 | 0000:03:00.0 Off | 0 0 |
| 30% 59 C P0 N/A / N/A | 0% 6MB / 2687MB | 0% Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| No running compute processes found |
Also… just in case cause I have seen a few people say about the version of nvcc:
[B@tman cuda-sdk]# nvcc --version
Copyright (c) 2005-2012 NVIDIA Corporation
Built on Thu_Apr__5_00:24:31_PDT_2012
Cuda compilation tools, release 4.2, V0.2.1221
