So I’ve been beating my head in for the last couple days trying to figure out what is wrong when I try to run the glx dependent SDK samples.
The following errors occur when I try to run the programs (they compile successfully):
[codebox][ CUDA Smoke Particles ]
freeglut (./smokeParticles): ERROR: Internal error in function fgOpenWindow
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 4 (X_DestroyWindow)
Resource id in failed request: 0x0
Serial number of failed request: 30
Current serial number in output stream: 33
[/codebox]
I’ve noticed this same error in previous posts but the fix didn’t seem to work. Also I get the same error with both direct and indirect rendering
I am running a fresh install of ubuntu 10.04, drivers 195.36.15, and the CUDA 3.0 toolkit. Also using freeglut and the latest mesa libraries (in order to compile the code).
Here is also a copy of my xorg.conf file
[codebox]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder75) Fri Mar 12 01:42:27 PST 2010
Section “ServerLayout”
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section “Monitor”
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section “Device”
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section “Screen”
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
[/codebox]
Any ideas would be great.
