This is program for vector addition using cudaStream.
#include<wb.h>
#define SEG_SIZE 256*4
#define NUM_STREAMS 4
#define wbCheck(stmt) \
do { \
cudaError_t err = stmt; \
if (err != cudaSuccess) { \
wbLog(ERROR, "Failed to run stmt ", #stmt); \
wbLog(ERROR, "Got CUDA error ... ", cudaGetErrorString(err)); \
return -1; \
} while (0)
__global__ void vecAdd(float * in1, float * in2, float * out, int len) {
int i = blockIdx.x * blockDim.x + threadIdx.x;
//printf("i: %d; in1: %f; in2: %f\n", i, in1[i], in2[i]);
if ( i < len ) out[i] = in1[i] + in2[i];
int main(int argc, char ** argv) {
wbArg_t args;
int inputLength;
float * hostInput1;
float * hostInput2;
float * hostOutput;
//streaming variables
float * deviceA0, *deviceB0, *deviceC0;
float * deviceA1, *deviceB1, *deviceC1;
float * deviceA2, *deviceB2, *deviceC2;
float * deviceA3, *deviceB3, *deviceC3;
//final, built result
float * deviceOutput;
args = wbArg_read(argc, argv);
wbTime_start(Generic, "Importing data and creating memory on host");
hostInput1 = (float *) wbImport(wbArg_getInputFile(args, 0), &inputLength);
hostInput2 = (float *) wbImport(wbArg_getInputFile(args, 1), &inputLength);
hostOutput = (float *) malloc(inputLength * sizeof(float));
wbTime_stop(Generic, "Importing data and creating memory on host");
wbLog(TRACE, "The input length is", inputLength);
wbTime_start(GPU, "Create some streams.");
cudaStream_t stream0, stream1, stream2, stream3;
cudaStreamCreate(&stream0);
cudaStreamCreate(&stream1);
cudaStreamCreate(&stream2);
cudaStreamCreate(&stream3);
wbTime_stop(GPU, "Create some streams.");
wbTime_start(GPU, "Allocate GPU memory.");
int size = SEG_SIZE * sizeof(float);
//streaming alloc
wbCheck(cudaMalloc((void **) &deviceA0, size));
wbCheck(cudaMalloc((void **) &deviceA1, size));
wbCheck(cudaMalloc((void **) &deviceA2, size));
wbCheck(cudaMalloc((void **) &deviceA3, size));
wbCheck(cudaMalloc((void **) &deviceB0, size));
wbCheck(cudaMalloc((void **) &deviceB1, size));
wbCheck(cudaMalloc((void **) &deviceB2, size));
wbCheck(cudaMalloc((void **) &deviceB3, size));
wbCheck(cudaMalloc((void **) &deviceC0, size));
wbCheck(cudaMalloc((void **) &deviceC1, size));
wbCheck(cudaMalloc((void **) &deviceC2, size));
wbCheck(cudaMalloc((void **) &deviceC3, size));
//final alloc
wbCheck(cudaMalloc((void **) &deviceOutput, size));
wbTime_stop(GPU, "Allocate GPU memory.");
wbTime_start(GPU, "Main stream loop");
for (int i = 0; i < inputLength; i+=SEG_SIZE*NUM_STREAMS){
//interleaved HostToDevice loading
printf("hostinput1 first: %f\n", *(hostInput1 + i));
cudaMemcpyAsync(deviceA0, hostInput1 + i , SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream0);
cudaMemcpyAsync(deviceB0, hostInput2 + i , SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream0);
cudaMemcpyAsync(deviceA1, hostInput1 + i + SEG_SIZE , SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream1);
cudaMemcpyAsync(deviceB1, hostInput2 + i + SEG_SIZE , SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream1);
cudaMemcpyAsync(deviceA2, hostInput1 + i + SEG_SIZE*2, SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream2);
cudaMemcpyAsync(deviceB2, hostInput2 + i + SEG_SIZE*2, SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream2);
cudaMemcpyAsync(deviceA3, hostInput1 + i + SEG_SIZE*3, SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream3);
cudaMemcpyAsync(deviceB3, hostInput2 + i + SEG_SIZE*3, SEG_SIZE*sizeof(float), cudaMemcpyHostToDevice, stream3);
//vecAdd on each stream
vecAdd<<<SEG_SIZE/256,256,0,stream0>>>(deviceA0, deviceB0, deviceC0, SEG_SIZE);
vecAdd<<<SEG_SIZE/256,256,0,stream1>>>(deviceA1, deviceB1, deviceC1, SEG_SIZE);
vecAdd<<<SEG_SIZE/256,256,0,stream2>>>(deviceA2, deviceB2, deviceC2, SEG_SIZE);
vecAdd<<<SEG_SIZE/256,256,0,stream3>>>(deviceA3, deviceB3, deviceC3, SEG_SIZE);
//DeviceToHost updates
cudaMemcpyAsync(hostOutput + i , deviceC0, SEG_SIZE*sizeof(float), cudaMemcpyDeviceToHost, stream0);
cudaMemcpyAsync(hostOutput + i + SEG_SIZE , deviceC1, SEG_SIZE*sizeof(float), cudaMemcpyDeviceToHost, stream1);
cudaMemcpyAsync(hostOutput + i + SEG_SIZE*2, deviceC2, SEG_SIZE*sizeof(float), cudaMemcpyDeviceToHost, stream2);
cudaMemcpyAsync(hostOutput + i + SEG_SIZE*3, deviceC3, SEG_SIZE*sizeof(float), cudaMemcpyDeviceToHost, stream3);
wbTime_stop(GPU, "Main stream loop");
wbSolution(args, hostOutput, inputLength);
free(hostInput1);
free(hostInput2);
free(hostOutput);
return 0;
In this program I am getting segmentation fault exception:
Exception thrown at 0x00007FFE40E1AC60 (ntdll.dll) in testStream.exe: 0xC0000005: Access violation reading location 0xFFFFFFFFFFFFFFFF.
If there is a handler for this exception, the program may be safely continued.
