Cuda select device and memory
Assume I have two GPUs
I select the first one using cudaselectdevice and copy some stuff to the GPU
Then I selected the second one and I copy some other stuff to the GPU
If I then select the first GPU again using cudaselectdevice and try to access what I copied in the beginning, will it still be there?
Thanks !
Yes, it will still be there. (wouldn’t this be easy enough just to try it and see?)
And the call is cudaSetDevice()
