- I installed the latest Titan V driver as of January 3, 2018, and then re-installed Cuda toolkit 9.1 to get the message
“This graphics driver could not find compatible graphics hardware. You may continue installation, but you may not be ablle to run CUDA applications with this driver…”
cannot compile anything in command prompt using nvcc
can’t build any CUDA samples in visual studio (tried modifying host_config.h file, and setting visual studio to 2015 version)
tensorflow scripts take between 1-10 minutes to set up the GPU before they start running…
what is going on? Is CUDA just ot connected to the titan V?
