Hey guys, I want to do SHA-1 on Cuda (little bruteforce project, but at first I want to make it work).
#include "sha_function.h"
/* f1 to f4 */
#define f1(x,y,z) ( ( x & y ) | ( ~x & z ) )
#define f2(x,y,z) ( x ^ y ^ z )
#define f3(x,y,z) ( ( x & y ) | ( x & z ) | ( y & z ) )
#define f4(x,y,z) ( x ^ y ^ z )
/* SHA init values */
#define I1 0x67452301L
#define I2 0xEFCDAB89L
#define I3 0x98BADCFEL
#define I4 0x10325476L
#define I5 0xC3D2E1F0L
/* SHA constants */
#define C1 0x5a827999L
#define C2 0x6ed9eba1L
#define C3 0x8f1bbcdcL
#define C4 0xca62c1d6L
/* 32-bit rotate */
#define ROT(x,n) ( ( x << n ) | ( x >> ( 32 - n ) ) )
/* main function */
#define CALC(n,i) temp = ( ROT ( A , 5 ) + f##n( B , C, D ) ) + ( W[i] + ( E + C##n ) ); E = D; D = C; C = ROT ( B , 30 ); B = A; A = temp
int main()
unsigned long * hash = (unsigned long *) malloc(4);
int length = 6;
start(hash, length);
return 1;
void start(unsigned long * hash, int length)
unsigned long * buffer = 0;
unsigned long * res = 0;
res = (unsigned long*) malloc(5 * sizeof(unsigned long));
cudaMalloc((void** ) &buffer, 5 * sizeof(unsigned long));
unsigned char input[length];
input[0] = 'a';
input[1] = 'a';
input[2] = 'a';
input[3] = 'a';
input[4] = 'a';
input[5] = 'a';
doSHA<<<1,1>>>(input, length, buffer);
cudaMemcpy(res, buffer, 5 * sizeof(unsigned long), cudaMemcpyDeviceToHost);
printf("%X\n", res[0]);
The printf at the end of the function prints 0 :( not what it should do. I think it’s a very stupid fault again. Ignore the variable “hash” that is passed to the function, it’s for the bruteforcer later. The rest of the code looks like that:
__global__ void doSHA(unsigned char * input, int length, unsigned long * buffer)
unsigned long W[80],A,B,C,D,E,temp;
memInit(W, input, length);
for(int i = 16; i < 80; i++)
W[i] = ( W[i-3] ^ W[i-8] ^ W[i-14] ^ W[i-16] );
A = I1; B = I2; C = I3; D = I4; E = I5;
CALC(1,0); CALC(1,1); CALC(1,2); CALC(1,3); CALC(1,4);
CALC(1,5); CALC(1,6); CALC(1,7); CALC(1,8); CALC(1,9);
CALC(1,10); CALC(1,11); CALC(1,12); CALC(1,13); CALC(1,14);
CALC(1,15); CALC(1,16); CALC(1,17); CALC(1,18); CALC(1,19);
CALC(2,20); CALC(2,21); CALC(2,22); CALC(2,23); CALC(2,24);
CALC(2,25); CALC(2,26); CALC(2,27); CALC(2,28); CALC(2,29);
CALC(2,30); CALC(2,31); CALC(2,32); CALC(2,33); CALC(2,34);
CALC(2,55); CALC(2,36); CALC(2,37); CALC(2,38); CALC(2,39);
CALC(3,40); CALC(3,41); CALC(3,42); CALC(3,43); CALC(3,44);
CALC(3,45); CALC(3,46); CALC(3,47); CALC(3,48); CALC(3,49);
CALC(3,50); CALC(3,51); CALC(3,52); CALC(3,53); CALC(3,54);
CALC(3,55); CALC(3,56); CALC(3,57); CALC(3,58); CALC(3,59);
CALC(4,60); CALC(4,61); CALC(4,62); CALC(4,63); CALC(4,64);
CALC(4,65); CALC(4,66); CALC(4,67); CALC(4,68); CALC(4,69);
CALC(4,70); CALC(4,71); CALC(4,72); CALC(4,73); CALC(4,74);
CALC(4,75); CALC(4,76); CALC(4,77); CALC(4,78); CALC(4,79);
buffer[0] = A;
buffer[1] = B;
buffer[2] = C;
buffer[3] = D;
buffer[4] = E;
__device__ void memInit(unsigned long * tmp, unsigned char * input, int length)
int stop = 0;
// reseting tmp
for(int i = 0; i < 80; i++) tmp[i] = 0;
// fill tmp like: message char c0,c1,c2,...,cn,10000000,00...000
for(int i = 0; i < length; i+=4)
for(int j = 0; j < 4; j++)
if(i + j < length)
tmp[i/4] |= input[i+j] << (24 - j * 8);
else
tmp[i/4] |= 0x80; // Append 1 then zeros
stop = 1;
break;
if(stop)
break;
// Adding length as last value
tmp[15] |= length;
Ty for your help guy, once more!
