CUDA shared memory with OpenACC
I am trying to accelerate my function with shared meory, since it worked for me with cuda hand-writing but it does not work :
first I notices that allocation do not happen with 1D allocated memory ,
here is my code
void function(int32_t bpl, int32_t h, int32_t w,
                    const uint8_t*restrict dispEstL,
                    const uint8_t*restrict vgL,
                    const uint8_t*restrict vgR,
                    const uint8_t*restrict hgL,
                    const uint8_t*restrict hgR,
                    const uint8_t*restrict D1min,
                    const uint8_t*restrict D1max,
                    const uint8_t**restrict tmp,
                    float * D1
// some initializations
#pragma acc kernels copyin(tmp[h][bpl], dispEstL[0:h*w], vgL[0:h*bpl], vgR[0:h*bpl], hgL[0:h*bpl], hgR[0:h*bpl], D1max[0:h], D1min[0:h], P[0:disp_num]) copy(D1[0:h*w])
    //#pragma acc parallel present(tmp[h][bpl], dispEstL[0:h*w], vgL[0:h*bpl], vgR[0:h*bpl], hgL[0:h*bpl], hgR[0:h*bpl], D1max[0:h], D1min[0:h], P[0:disp_num], D1[0:h*w])
        #pragma acc loop independent gang vector //gang(12) vector(32)
        for(int32_t v=2; v<h-2; v++)
            #pragma acc loop independent gang vector //gang(39) vector(32) private(v)
            for( int32_t  u=2; u<w-2; u++)
                #pragma acc cache(hgL[v-2:v+2][u-2:u+2], vgL[v-1:v+1][u-1:u+1], hgR[v-2:v+2][u-2:u+2], vgR[v-1:v+1][u-1:u+1])
                    int32_t v_tmp = v;
                    int32_t u_tmp = u;
                    int32_t line_max = (int32_t)D1max[v_tmp];
                    int32_t line_min = (int32_t)D1min[v_tmp];
                    uint8_t d_plane     = dispEstL[v_tmp*w + u_tmp];
                    int32_t min_val= 10000;
                    int32_t min_d  = -1;
                    int32_t val, u_warp;
                    int32_t a, b;
                    a = v_tmp*bpl + u_tmp;
                    //#pragma acc loop seq
                    for ( int32_t d_curr=line_min; d_curr<=line_max; d_curr++)
                        u_warp = u_tmp-d_curr;
                        if (u_warp<2 || u_warp>=w-2)
                            continue;
                        b = a - d_curr;
                        val = *(P+abs(d_curr-d_plane));
                        val += abs(*(hgL + (a-2*bpl))  - *(hgR + (b-2*bpl))) ;
                        val += abs(*(hgL + (a-bpl -2)) - *(hgR + (b-bpl -2))) ;
                        val += abs(*(hgL + (a-bpl ))   - *(hgR + (b-bpl))) ;
                        val += abs(*(hgL + (a-bpl +2)) - *(hgR + (b-bpl +2))) ;
                        val += abs(*(hgL + (a-1))      - *(hgR + (b-1))) ;
                        val += abs(*(hgL + (a))        - *(hgR + (b))) ;
                        val += abs(*(hgL + (a+1))      - *(hgR + (b+1))) ;
                        val += abs(*(hgL + (a+bpl -2)) - *(hgR + (b+bpl -2))) ;
                        val += abs(*(hgL + (a+bpl ))   - *(hgR + (b+bpl ))) ;
                        val += abs(*(hgL + (a+bpl +2)) - *(hgR + (b+bpl +2))) ;
                        val += abs(*(hgL + (a+2*bpl )) - *(hgR + (b+2*bpl ))) ;
                        val += abs(*(vgL + (a-bpl ))   - *(vgR + (b-bpl ))) ;
                        val += abs(*(vgL + (a-1))      - *(vgR + (b-1))) ;
                        val += abs(*(vgL + (a+1))      - *(vgR + (b+1))) ;
                        val += abs(*(vgL + (a+bpl ))   - *(vgR + (b+bpl ))) ;
                        if (val<min_val) {
                            min_val = val;
                            min_d = d_curr;
                    if (min_d>=0) *(D1+v*w + u) = (float)min_d; // MAP value (min neg-Log probability)
                    else          *(D1+v*w + u) = -1;           // invalid disparity
   delete[] P;
even though the compiler says that it has referenced the above arrays in the cache, I noticed that the execution time did not change .
Then, I profiled with nvprof -m shared_load_transactions,shared_store_transactions and I found that not load has been performed on the shared memory .
I modified the above function to work on 2D allocated arrays, (uint8_t**) …
The execution time has been increased even with no shared memory .
Then , with shared memory, it does the allocations for some arrays not for all .
I did not find any doc concerning the shared memory with OpenACC.
Could you please help and explain me the above results :
Why it works only on 2D allocated arrays ?
why it works only on few arrays ?
Thank you
/Djamila
Hi Djamila,
We’ve had issues with the cache directive where the compiler would set up the shared memory but not use it within inner loops where it’s analysis couldn’t determine the accesses were bounded within the cache dimensions. That’s most likely the case here since you’re using pointer arithmetic.
Recently, we have done quite a bit of work improving this with the improvements being available in the upcoming 17.1 release (or 17.4 if you are using the Community Edition). Once available, please update to the new compilers. If you still don’t see the shared memory usage, please let us know and we can take a look at your particular code to understand why it’s not working as expected.
Best Regards,
Mat
Hi Mat,
Thank you for your response.
Hope it will work in the next release.
Best regards,
Djamila
