I implement simpleStreams after install CUDA. But PC is terminate.
OS
- ubuntu 16.04
GPU
- GeForce RTX 2060/PCIe/SSE2
NVIDIA Driver Version and CUDA Version
Tue May 7 13:47:38 2019
| NVIDIA-SMI 418.56 Driver Version: 418.56 CUDA Version: 10.1 |
| 0 GeForce RTX 2060 Off | 00000000:01:00.0 On | N/A |
| 22% 57C P8 15W / 160W | 230MiB / 5902MiB | 2% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 992 G /usr/lib/xorg/Xorg 156MiB |
| 0 1623 G compiz 68MiB |
| 0 2195 G /usr/lib/firefox/firefox 3MiB |
but, asyncAPI and deviceQuery are not terminate.
[./asyncAPI] - Starting…
GPU Device 0: “GeForce RTX 2060” with compute capability 7.5
CUDA device [GeForce RTX 2060]
time spent executing by the GPU: 11.34
time spent by CPU in CUDA calls: 0.02
CPU executed 61282 iterations while waiting for GPU to finish
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
CUDA Driver Version / Runtime Version 10.1 / 10.1
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 5902 MBytes (6188761088 bytes)
(30) Multiprocessors, ( 64) CUDA Cores/MP: 1920 CUDA Cores
GPU Max Clock rate: 1695 MHz (1.70 GHz)
Memory Clock rate: 7001 Mhz
Memory Bus Width: 192-bit
L2 Cache Size: 3145728 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 3 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.1, CUDA Runtime Version = 10.1, NumDevs = 1
Result = PASS
Please reply.
