CUDA strlen() implementation - what's wrong? Works fine on emulator and does not on GPU
Here is the code, which works fine with -deviceemu option (result is 17) and
doesn’t work on real GPU. Please help, what’s wrong and how to fix it?
[codebox]#include <stdio.h>
#include <cuda.h>
#define MAX_SIZE 255
global void strlenDevice(char *str, int *len) {
int i = blockIdx.x * blockDim.x + threadIdx.x;
// Process each char in each thread
// If char is ‘\0’ then it’s possibly end-of-string
// Choose a minimal of that chars
if (i < MAX_SIZE)
 if (str[i] == '\0') if ( i< *len) *len =i;
int main(void) {
char *device_str; // pointers to device memory
char str[MAX_SIZE]; // string
int *pLen = NULL;
int len;
// allocate string on device
cudaMalloc((void **) &device_str, MAX_SIZE);
// allocate length
cudaMalloc( (void**) &pLen, 4 );
// set string
strcpy(str, “Hello CUDA World!”);
// len = maximal value
len = MAX_SIZE;
// send data from host to device
cudaMemcpy (device_str, str, MAX_SIZE, cudaMemcpyHostToDevice);
cudaMemcpy (pLen, &len, 4, cudaMemcpyHostToDevice );
// data copied on device, invoking kernel
strlenDevice <<< 1, 256 >>> (device_str, pLen);
// retrieve data from device
cudaMemcpy( &len, pLen, 4, cudaMemcpyDeviceToHost );
// print strlen
 printf ("strlen = %d", len);
}[/codebox]
I think you should update and read len through an atomic function, if there are multiple terminating characters after your string you do not know what your result will be. Eg.
mystring[10] = “hello\0yyy\0”;. Now you have to remember that deviceemulation is only emulation and not truly parallel. In your GPU threads 5 and 9 will find a terminating character. Since i is smaller than MAX_SIZE (the value of len), both will update it. Both will write to that memory location, but only one will succeed. Which one… is undetermined.
