Recently we purchased a Dell Precision 3640 workstation which comes with a Nvidia Quadro RTX-4000 graphic card. While trying to run our Tensorflow application (Python code) it exits the code abruptly with the statement - Process finished with exit code -1073740791 (0xC0000409). I’ve installed the CUDA 11.2 version for it. The statements displayed after executing the code is given below. Please provide a solution for it.
E:\PYTHON3.7\python.exe E:/CLA_30_MAR_21/RegressionTest.py
2021-04-21 10:21:51.147641: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudart64_110.dll
2021-04-21 10:21:52.319800: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2021-04-21 10:21:52.322088: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library nvcuda.dll
2021-04-21 10:21:52.343070: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1720] Found device 0 with properties:
pciBusID: 0000:01:00.0 name: Quadro RTX 4000 computeCapability: 7.5
coreClock: 1.545GHz coreCount: 36 deviceMemorySize: 8.00GiB deviceMemoryBandwidth: 387.49GiB/s
2021-04-21 10:21:52.343217: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudart64_110.dll
2021-04-21 10:21:52.759802: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublas64_11.dll
2021-04-21 10:21:52.759887: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublasLt64_11.dll
2021-04-21 10:21:53.041830: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cufft64_10.dll
2021-04-21 10:21:53.071279: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library curand64_10.dll
2021-04-21 10:21:53.273078: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cusolver64_10.dll
2021-04-21 10:21:53.457406: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cusparse64_11.dll
2021-04-21 10:21:53.460055: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudnn64_8.dll
2021-04-21 10:21:53.460180: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1862] Adding visible gpu devices: 0
2021-04-21 10:21:53.856994: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1261] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-04-21 10:21:53.857082: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1267] 0
2021-04-21 10:21:53.857129: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1280] 0: N
2021-04-21 10:21:53.857290: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1406] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 4096 MB memory) → physical GPU (device: 0, name: Quadro RTX 4000, pci bus id: 0000:01:00.0, compute capability: 7.5)
2021-04-21 10:21:53.857970: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-04-21 10:21:54.205068: I tensorflow/compiler/jit/xla_cpu_device.cc:41] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-04-21 10:21:54.205194: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1720] Found device 0 with properties:
2021-04-21 10:21:54.205339: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudart64_110.dll
2021-04-21 10:21:54.205412: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublas64_11.dll
2021-04-21 10:21:54.205482: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublasLt64_11.dll
2021-04-21 10:21:54.205554: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cufft64_10.dll
2021-04-21 10:21:54.205624: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library curand64_10.dll
2021-04-21 10:21:54.205696: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cusolver64_10.dll
2021-04-21 10:21:54.205767: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cusparse64_11.dll
2021-04-21 10:21:54.205841: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudnn64_8.dll
2021-04-21 10:21:54.205932: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1862] Adding visible gpu devices: 0
2021-04-21 10:21:54.206114: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1720] Found device 0 with properties:
2021-04-21 10:21:54.206255: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudart64_110.dll
2021-04-21 10:21:54.206327: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublas64_11.dll
2021-04-21 10:21:54.206399: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublasLt64_11.dll
2021-04-21 10:21:54.206471: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cufft64_10.dll
2021-04-21 10:21:54.206543: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library curand64_10.dll
2021-04-21 10:21:54.206615: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cusolver64_10.dll
2021-04-21 10:21:54.206691: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cusparse64_11.dll
2021-04-21 10:21:54.206763: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudnn64_8.dll
2021-04-21 10:21:54.206860: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1862] Adding visible gpu devices: 0
2021-04-21 10:21:54.206943: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1261] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-04-21 10:21:54.207016: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1267] 0
2021-04-21 10:21:54.207063: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1280] 0: N
2021-04-21 10:21:54.207166: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1406] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 4096 MB memory) → physical GPU (device: 0, name: Quadro RTX 4000, pci bus id: 0000:01:00.0, compute capability: 7.5)
2021-04-21 10:21:54.207317: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-04-21 10:21:55.410007: I tensorflow/compiler/mlir/mlir_graph_optimization_pass.cc:116] None of the MLIR optimization passes are enabled (registered 2)
2021-04-21 10:21:55.830841: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublas64_11.dll
2021-04-21 10:21:56.607131: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cublasLt64_11.dll
2021-04-21 10:21:56.610075: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library cudnn64_8.dll
