CUDA/Thrust double pointer problem (vector of pointers)
Hey all, I am using CUDA and the Thrust library. I am running into a problem when I try to access a double pointer on the CUDA kernel loaded with a thrust::device_vector of type Object* (vector of pointers) from the host. When compiled with ‘nvcc -o thrust main.cpp cukernel.cu’ i receive the warning ‘Warning: Cannot tell what pointer points to, assuming global memory space’ and a launch error upon attempting to run the program.
I have read the Nvidia forums and the solution seems to be ‘Don’t use double pointers in a CUDA kernel’. I am not looking to collapse the double pointer into a 1D pointer before sending to the kernel…Has anyone found a solution to this problem? The required code is below, thanks in advance!
        main.cpp
Sphere * parseSphere(int i)
  Sphere * s = new Sphere();
  s->a = 1+i;
  s->b = 2+i;
  s->c = 3+i;
  return s;
int main( int argc, char** argv ) {
int i;
  thrust::host_vector<Sphere *> spheres_h;
  thrust::host_vector<Sphere> spheres_resh(NUM_OBJECTS);
//initialize spheres_h
  for(i=0;i<NUM_OBJECTS;i++){
    Sphere * sphere = parseSphere(i);
    spheres_h.push_back(sphere);
//initialize spheres_resh
    spheres_resh[i].a = 1;
    spheres_resh[i].b = 1;
    spheres_resh[i].c = 1;
thrust::device_vector<Sphere *> spheres_dv = spheres_h;
  thrust::device_vector<Sphere> spheres_resv = spheres_resh;
  Sphere ** spheres_d = thrust::raw_pointer_cast(&spheres_dv[0]);
  Sphere * spheres_res = thrust::raw_pointer_cast(&spheres_resv[0]);
kernelBegin(spheres_d,spheres_res,NUM_OBJECTS);
thrust::copy(spheres_dv.begin(),spheres_dv.end(),spheres_h.begin());
  thrust::copy(spheres_resv.begin(),spheres_resv.end(),spheres_resh.begin());
bool result = true;
    result &= (spheres_resh[i].a == i+1);
    result &= (spheres_resh[i].b == i+2);
    result &= (spheres_resh[i].c == i+3);
if(result)
    cout << "Data GOOD!" << endl;
  }else{
    cout << "Data BAD!" << endl;
return 0;
        cukernel.cu
__global__ void deviceBegin(Sphere ** spheres_d, Sphere * spheres_res, float num_objects)
  int index = threadIdx.x + blockIdx.x*blockDim.x;
spheres_res[index].a = (*(spheres_d+index))->a; //causes warning/launch error
  spheres_res[index].b = (*(spheres_d+index))->b;
  spheres_res[index].c = (*(spheres_d+index))->c;
void kernelBegin(Sphere ** spheres_d, Sphere * spheres_res, float num_objects)
int threads = 512;//per block
 int grids = ((num_objects)/threads)+1;//blocks per grid
deviceBegin<<<grids,threads>>>(spheres_d, spheres_res, num_objects);
