Also posted on SO, although so far no joy. It looks like recent changes to Thrust were made to tag the host_vector
class name with the compile time CUDA architecture. This creates an issue (undefined reference) when linking shared objects compiled with nvcc or not (.cu
vs .cpp
files) that use Thrust objects, even host only ones like host_vector
We have a large application that uses host_vector
in many .cpp
files, and compiling everything with nvcc is probably not an option, some of the files need moc (ie Qt).
To reproduce on Ubuntu 20.04.6 LTS with Cuda 12.6:
Main.cpp:
include <cuda_runtime.h>
include <thrust/host_vector.h>
bool cudaFunc(thrust::host_vector &vec);
int main()
thrust::host_vector vec;
cudaFunc(vec);
cudaFunc.cu:
return true;
Compile with:
/usr/local/cuda/bin/nvcc -c cudaFunc.cu
g++ -I /usr/local/cuda/include -L /usr/local/cuda/targets/x86_64-linux/lib main.cpp cudaFunc.o -lcudart -ldl
will produce the error:
/usr/bin/ld: /tmp/cc5fFAJC.o: in function main:
main.cpp:(.text+0x30): undefined reference to cudaFunc(thrust::THRUST_200500___CUDA_ARCH_LIST___NS::host_vector<int, std::allocator >&)
This will link fine on Ubuntu 20 with Cuda 12.3.
Does anyone know if this is a bug? (so it might get fixed) or is compiling thrust objects in both .cu files and .cpp files not supported?
