I’m trying to use CUDA toolkit 12.0.0 and I got QA issue regarding the runtime dependency.
Kindly see the log below.
ERROR: libcublas-12.0.1.189-1-r0 do_package_qa: QA Issue: /usr/local/cuda-12.0/lib/stubs/libcublasLt.so contained in package libcublas-stubs requires libc.so.6(GLIBC_2.17)(64bit), but no providers found in RDEPENDS:libcublas-stubs? [file-rdeps]
ERROR: libcublas-12.0.1.189-1-r0 do_package_qa: QA Issue: /usr/local/cuda-12.0/lib/stubs/libcublasLt.so contained in package libcublas-stubs requires libc.so.6()(64bit), but no providers found in RDEPENDS:libcublas-stubs? [file-rdeps]
$ readelf -d ./usr/local/cuda-12.0/lib64/stubs/libcublas.so
Dynamic section at offset 0x12d90 contains 31 entries:
Tag Type Name/Value
0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
0x000000000000000e (SONAME) Library soname: [libcublas.so.12]
0x0000000000000010 (SYMBOLIC) 0x0
0x000000000000001d (RUNPATH) Library runpath: [$ORIGIN]
$ readelf -d ./usr/local/cuda-12.0/lib64/stubs/libcublasLt.so
Dynamic section at offset 0x9d90 contains 31 entries:
Tag Type Name/Value
0x000000000000000e (SONAME) Library soname: [libcublasLt.so.12]
FYI, I don’t see anything specific that require GLIBC when checking the symbols needed by the libraries mentioned in the title.
$ readelf -w --dyn-syms ./usr/local/cuda-12.0/lib64/stubs/libcublas.so
Symbol table '.dynsym' contains 745 entries:
Num: Value Size Type Bind Vis Ndx Name
0: 0000000000000000 0 NOTYPE LOCAL DEFAULT UND
1: 000000000000a760 0 SECTION LOCAL DEFAULT 10
2: 0000000000023018 0 SECTION LOCAL DEFAULT 22
3: 0000000000000000 0 NOTYPE WEAK DEFAULT UND _ITM_deregisterTMCloneTab
4: 0000000000000000 0 FUNC WEAK DEFAULT UND __cxa_finalize@GLIBC_2.17 (3)
5: 0000000000000000 0 NOTYPE WEAK DEFAULT UND __gmon_start__
6: 0000000000000000 0 FUNC GLOBAL DEFAULT UND puts@GLIBC_2.17 (3)
7: 0000000000000000 0 NOTYPE WEAK DEFAULT UND _ITM_registerTMCloneTable
8: 000000000000c760 12 FUNC GLOBAL DEFAULT 12 cublasXtCsymm@@libcublas.so.12
9: 000000000000aee0 12 FUNC GLOBAL DEFAULT 12 cublasZtbmv_v2@@libcublas.so.12
$ readelf -w --dyn-syms ./usr/local/cuda-12.0/lib64/stubs/libcublasLt.so
Symbol table '.dynsym' contains 300 entries:
1: 0000000000005be8 0 SECTION LOCAL DEFAULT 10
2: 000000000001a018 0 SECTION LOCAL DEFAULT 22
8: 0000000000006470 12 FUNC GLOBAL DEFAULT 12 cublasLtBSSMatmulAlgoChec@@libcublasLt.so.12
9: 0000000000005ee0 12 FUNC GLOBAL DEFAULT 12 cublasLtCreate@@libcublasLt.so.12
Attached file contains the complete logs.
readelf_syms_libcublas.log (161.8 KB)
readelf_syms_libcublasLt.log (68.3 KB)
Could you please explain why GLIBC is needed ?
Any help would be much appreciated.
Best regards,
Ilies
