I have strange thing happened to my CUDA Toolkit 5.0.
Few days ago both XCode and NSight Eclipse plugin lost ability to build even simplest CUDA related projects. XCode successfully building projects with custom build rule for C++ source files:
nvcc "INPUT_FILE_NAME"
But console output shows that run failed
error: executable doesn't exist: '/Users/geraldus/Library/Developer/Xcode/DerivedData/CUDA_Hello_World-gzfzqivvsmeamfghnovopxapkdsz/Build/Products/Debug/CUDA Hello World'
error: failed to launch '/Users/geraldus/Library/Developer/Xcode/DerivedData/CUDA_Hello_World-gzfzqivvsmeamfghnovopxapkdsz/Build/Products/Debug/CUDA Hello World' -- SBTarget is invaliderror: failed to launch '/Users/geraldus/Library/Developer/Xcode/DerivedData/CUDA_Hello_World-gzfzqivvsmeamfghnovopxapkdsz/Build/Products/Debug/CUDA Hello World' -- SBTarget is invalid
And Eclipse NSight output always shows that .o file is missing.
**** Build of configuration Release for project Simple CUDA RT ****
make all
Building file: ../src/Simple CUDA RT.cu
Invoking: NVCC Compiler
nvcc -O3 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_35,code=sm_35 -odir "src" -M -o "src/Simple CUDA RT.d" "../src/Simple CUDA RT.cu"
nvcc -O3 "src/Simple CUDA RT.o" "../src/Simple CUDA RT.cu"
i686-apple-darwin11-llvm-g++-4.2: src/Simple CUDA RT.o: No such file or directory
make: *** [src/Simple CUDA RT.o] Error 1
**** Build Finished ****
I’ve tried to rebuild CUDA samples this way:
cd /Developer/NVIDIA/CUDA-5.0/samples
make clean
make
Everything was built without errors, binaries were successfully generated and they works. But still the same situation with XCode and Eclipse (even after reinstalling Eclipse and CUDA Toolkit)
How can I fix it? Is it a bug or my incorrect actions?
