I run the cuda installer and get error saying all not-installed. I ran also extracted the files and ran:
setup.exe -log:"F:\NVIDIA_CUDA" -loglevel:6
This did not seem to make a difference. Logs attached.
The only real error I see before the installer goes into failed mode is this one:
DEBUG: [DisplayDriver.DisplayDriverExtSite] 1698@CDisplayDriverExtSite::MapINFFlagsToProperties : Found NVAllowMCVirtualAudioPreStage with value of 0.
24.474 | INFO: [DisplayDriver.DisplayDriverExtSite] 3149@CDisplayDriverExtSite::ProcessDowngradeBehavior : Clean install on downgrade is not required in the extension.
24.474 | INFO: [DisplayDriver.DisplayDriverExtSite] 3049@CDisplayDriverExtSite::ProcessForceCleanBehavior : Force clean is not required in the extension.
24.474 | DEBUG: [DisplayDriver.DisplayDriverExtSite] 4083@CDisplayDriverExtSite::PerformOptimusRemovalAnalysis : Determining if Optimus should be removed.
24.474 | DEBUG: [DisplayDriver.DisplayDriverExtSite] 4146@CDisplayDriverExtSite::PerformOptimusRemovalAnalysis : Optimus should remain, no further actions.
24.489 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0x80070002 - The system cannot find the file specified.; File: InstallationStepper.cpp; Line: 769; Extension failed during call toAnalyze} - going to fail state.
24.490 | DEBUG: [NVI2.Installation] 107@CInstallationStepper::Present : Presenting "!InstallFailed".
24.490 | INFO: [NVI2UI.MainFrame] 2589@CMainFrame::FlushEvents : Property changed "NextFormGroup".
Please let me know what steps I can try.
LOG.setup.exe.log (298 KB)
