I’m trying to execute CUDA software with Cuda Toolkit 4.1 installed:
SimplePrintf sample says:
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
value = 35 : Memory Allocation on GPU Device failed
Memory Copy from Host to Device failed.
Memory Copy from Device to Host failed.
Other more-complex program says:
WARNING: [?]Couldn’t initialize the GPU support component at runtime startup: CUDA driver version is insufficient for CUDA runtime version
Driver 285.05.33 installed. Aka lastest (the one provided with CUDA toolkit 4.1).
I’m running it on a shared machine where i’m not root, CUDA Toolkit is installed on my home directory, driver was installed and machine restarted. Machine has 285GTX SLI.
I need some permission or something else? Install older Cuda Toolkit?
Thanks,
PS: If i remove cudaStat = cudaMalloc ((void **)&cosArg, N * sizeof(cosArg[0])); all cudaMalloc calls, program will execute correctly and this cos_main<<<1,COS_THREAD_CNT>>>(funcParams) will work “fine” (altho printf wont show any change)
PS2: After installing toolkit 2.3 (the one for GTX 285 i think), i get -> no CUDA-capable device is available, i guess permission problem.
