Hi everyone,
I’m facing a lot of problem trying to run a pyhton script on my NVIDIA AGX XAVIER GPU using numba jit and cuda.
After resolving many errors, I’m feel I’m almost done with it ! But I get the following error :
File “/usr/lib/python3/dist-packages/numba/cuda/dispatcher.py”, line 42, in call
return self.compiled(*args, **kws)
File “/usr/lib/python3/dist-packages/numba/cuda/compiler.py”, line 701, in call
kernel = self.specialize(*args)
File “/usr/lib/python3/dist-packages/numba/cuda/compiler.py”, line 712, in specialize
kernel = self.compile(argtypes)
File “/usr/lib/python3/dist-packages/numba/cuda/compiler.py”, line 730, in compile
kernel.bind()
File “/usr/lib/python3/dist-packages/numba/cuda/compiler.py”, line 489, in bind
self._func.get()
File “/usr/lib/python3/dist-packages/numba/cuda/compiler.py”, line 370, in get
ptx = self.ptx.get()
File “/usr/lib/python3/dist-packages/numba/cuda/compiler.py”, line 342, in get
**self._extra_options)
File “/usr/lib/python3/dist-packages/numba/cuda/cudadrv/nvvm.py”, line 464, in llvm_to_ptx
libdevice = LibDevice(arch=opts.get(‘arch’, ‘compute_20’))
File “/usr/lib/python3/dist-packages/numba/cuda/cudadrv/nvvm.py”, line 340, in init
raise RuntimeError(MISSING_LIBDEVICE_FILE_MSG.format(arch=arch))
RuntimeError: Missing libdevice file for compute_50.
Please ensure you have package cudatoolkit 7.5.
Install package by:
conda install cudatoolkit=7.5
However, my Cuda compilation tools version is already release 10.2, V10.2.89.
Moreover, I red that conda is not supported buy agx xavier architecture
Should I try to install Anaconda ? and then install the cuda toolkit through conda ?
Should I downgrade my cudatoolkit ?
Is it possible to have 2 versions of the cuda toolkit running in the same machine ?
Thank you
