Cuda transfer from device to host is extremely slow
Hello ,
Im using the below code to create cuda stream and run inference on SSD mobile 320x320 V2 converted to tesnorrt .The inference is running fast but Im facing extreme slowness when moving the data back from device to host in the d_to_h steps .The inference is taking 5 ms while the transfer is taking 20 ms .
Is there anyhting in the code where i can enhance or improve the speed of transfrer and could this be an issue ?
Im usnig Xavier and TensorRT 8
class TensorRTInfer:
def __init__(self, engine):
    :param engine_path: The path to the serialized engine to load from disk.
    # Load TRT engine
    self.cfx = cuda.Device(0).make_context()
    self.stream = cuda.Stream()
    self.engine = engine
    self.context = self.engine.create_execution_context()
    # Setup I/O bindings
    self.inputs1 = []
    self.outputs1 = []
    self.allocations1 = []
    for i in range(self.engine.num_bindings):
        name = self.engine.get_binding_name(i)
        dtype = self.engine.get_binding_dtype(i)
        shape = self.engine.get_binding_shape(i)
        size = np.dtype(trt.nptype(dtype)).itemsize * 1
        for s in shape:
            size *= s
        allocation1 = cuda.mem_alloc(size)
        binding1 = {
            'index': i,
            'name': name,
            'dtype': np.dtype(trt.nptype(dtype)),
            'shape': list(shape),
            'allocation': allocation1,
        self.allocations1.append(allocation1)
        if self.engine.binding_is_input(i):
            self.inputs1.append(binding1)
        else:
            self.outputs1.append(binding1)
    self.outputs2 = []
    for shape, dtype in self.output_spec():
        shape[0]=shape[0] *1
        self.outputs2.append(np.zeros(shape, dtype))
    print("done building..")
def input_spec(self):
    Get the specs for the input tensor of the network. Useful to prepare memory allocations.
    :return: Two items, the shape of the input tensor and its (numpy) datatype.
    return self.inputs[0]['shape'], self.inputs[0]['dtype']
def output_spec(self):
    Get the specs for the output tensors of the network. Useful to prepare memory allocations.
    :return: A list with two items per element, the shape and (numpy) datatype of each output tensor.
    specs = []
    for o in self.outputs1:
        specs.append((o['shape'], o['dtype']))
    return specs
def h_to_d(self, batch):
    self.batch = batch
    cuda.memcpy_htod_async(self.inputs1[0]['allocation'], np.ascontiguousarray(batch))
def destory(self):
    self.cfx.pop()
def d_to_h(self):
  for o in range(len(self.outputs2)):
    cuda.memcpy_dtoh_async(self.outputs2[0], self.outputs1[0]['allocation'], self.stream)
    return self.outputs2
def infer_this(self):
    self.cfx.push()
    self.context.execute_async(batch_size=1,bindings=self.allocations1, stream_handle=self.stream.handle)
    self.cfx.pop()
Request you to share the model, script, profiler and performance output if not shared already so that we can help you better.
Alternatively, you can try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
While measuring the model performance, make sure you consider the latency and throughput of the network inference, excluding the data pre and post-processing overhead.
Please refer below link for more details:
https://docs.nvidia.com/deeplearning/tensorrt/archives/tensorrt-722/best-practices/index.html#measure-performance
https://docs.nvidia.com/deeplearning/tensorrt/best-practices/index.html#model-accuracy
model1_trt_16.trt (8.1 MB)
The complete code will be :
import os
import sys
from time import time, sleep, perf_counter
import time
import time
import ctypes
import argparse
import numpy as np
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
import threading
from concurrent.futures import ThreadPoolExecutor
from multiprocessing import Process, Queue, Manager
import multiprocessing
import cv2
    Implements inference for the Model TensorRT engine.
        # Load TRT engine
        self.inputs1 = []
        self.outputs1 = []
            for s in shape:
                size *= s
            binding1 = {
                'index': i,
                'name': name,
            else:
        self.outputs2 = []
        specs = []
        return specs
        self.batch = batch
    def destory(self):
        self.cfx.pop()
    def d_to_h(self):
        self.cfx.push()
        self.cfx.pop()
if __name__ == '__main__':
    logger = trt.Logger(trt.Logger.ERROR)
    trt.init_libnvinfer_plugins(logger, namespace="")
    engine = None
    with open('/home/zenith/Desktop/model1_16.trt', "rb") as f, trt.Runtime(logger) as runtime:
        engine1 = runtime.deserialize_cuda_engine(f.read())
    mat1 = cv2.imread('/home/zenith/Desktop/tf16/img108.jpg')
    stretch_near1 = cv2.resize(mat1, (640, 640))
    _image1 = np.expand_dims(stretch_near1, axis=0).astype(np.float32)
    images = np.random.rand(1, 640, 640, 3).astype(np.float32)
    trt_infer_big1 = TensorRTInfer(engine1)
    x = range(100)
    for n in x:
        tic = time.perf_counter()
        tiic = time.perf_counter()
        trt_infer_big1.h_to_d(_image1)
        tooc = time.perf_counter()
        vll = tooc - tiic
        print("h_to_d:" + str(vll))
        act1 = time.perf_counter()
        trt_infer_big1.infer_this()
        act2 = time.perf_counter()
        vll = act2 - act1
        print("inference:" + str(vll))
        teec = time.perf_counter()
        trt_infer_big1.d_to_h()
        toec = time.perf_counter()
        vll = toec - teec
        print("d_to_h:" + str(vll))
        toc = time.perf_counter()
        vll = toc - tic
        print("whole time:" + str(vll))
        sleep(0.05)
in the above for loop ,I’m trying to follow cuda concurrent pattern which should reduce the time considerably compared with linear approach .
You will notice the time for d_to_h in the loop is taking the largest amount of time while the inference is taking so little .
Any update please ?
Please refer to following. Which may help you.
Thank you.
