Cuda version doesn't appear while running version_checker.py
Im have a strange issue with isaac sdk and cuda. I wanted to controlle with “version_checker.py” the installed packages and their versions but Cuda isnt displayed a version although it’s installed.
-result of version_checker.py
-result of nvcc --version
The script does use nvcc to determine the version, but it uses a specific path to parse the information from: /usr/local/cuda/bin/nvcc. Could you check which nvcc to find out the path to yours? If you have multiple CUDA Toolkits installed, the path may not be the same I suspect.
