I’m trying to “upgrade” marchingcubes sample. I load a mesh and “voxel”-thing it.
For that i use on each vertex of each one voxels of a 16x16x16 grid (i have rescaled the grid for an easier debugging) an algorithm who tell me if i’m inside or outside of the mesh. Then i fill 16x16x16 uchar in a new raw file. The thing is that i’m not sure of how the raw is used :
// version that calculates flat surface normal for each triangle
__global__ void
generateTriangles2(float4 *pos, float4 *norm, uint *compactedVoxelArray, uint *numVertsScanned, uchar *volume,
uint3 gridSize, uint3 gridSizeShift, uint3 gridSizeMask,
float3 voxelSize, float isoValue, uint activeVoxels, uint maxVerts)
uint blockId = __mul24(blockIdx.y, gridDim.x) + blockIdx.x;
uint i = __mul24(blockId, blockDim.x) + threadIdx.x;
if (i > activeVoxels - 1)
i = activeVoxels - 1;
#if SKIP_EMPTY_VOXELS
uint voxel = compactedVoxelArray[i];
#else
uint voxel = i;
#endif
// compute position in 3d grid
uint3 gridPos = calcGridPos(voxel, gridSizeShift, gridSizeMask);
float3 p;
p.x = -1.0f + (gridPos.x * voxelSize.x);
p.y = -1.0f + (gridPos.y * voxelSize.y);
p.z = -1.0f + (gridPos.z * voxelSize.z);
// calculate cell vertex positions
float3 v[8];
v[0] = p;
v[1] = p + make_float3(voxelSize.x, 0, 0);
v[2] = p + make_float3(voxelSize.x, voxelSize.y, 0);
v[3] = p + make_float3(0, voxelSize.y, 0);
v[4] = p + make_float3(0, 0, voxelSize.z);
v[5] = p + make_float3(voxelSize.x, 0, voxelSize.z);
v[6] = p + make_float3(voxelSize.x, voxelSize.y, voxelSize.z);
v[7] = p + make_float3(0, voxelSize.y, voxelSize.z);
#if SAMPLE_VOLUME
<li>//!!!!!!!!!!!! OVER HERE !!!!!!!!!!!!!
//The field array (= ONE voxel data) is made with a grid of voxel loaded from the raw file.
//sampleVolume(see down) get a normalised unsigned float loaded from 8 bit (= 1 bytes = 1 uchar)
//My question is when i fill my raw with 16x16x16 bytes should each bytes be made from each vertex bool //of the voxel (assuming that i use the same order as their grid) ? </li>
float field[8];
field[0] = sampleVolume(volume, gridPos, gridSize);
field[1] = sampleVolume(volume, gridPos + make_uint3(1, 0, 0), gridSize);
field[2] = sampleVolume(volume, gridPos + make_uint3(1, 1, 0), gridSize);
field[3] = sampleVolume(volume, gridPos + make_uint3(0, 1, 0), gridSize);
field[4] = sampleVolume(volume, gridPos + make_uint3(0, 0, 1), gridSize);
field[5] = sampleVolume(volume, gridPos + make_uint3(1, 0, 1), gridSize);
field[6] = sampleVolume(volume, gridPos + make_uint3(1, 1, 1), gridSize);
field[7] = sampleVolume(volume, gridPos + make_uint3(0, 1, 1), gridSize);
#else
// evaluate field values
float field[8];
field[0] = fieldFunc(v[0]);
field[1] = fieldFunc(v[1]);
field[2] = fieldFunc(v[2]);
field[3] = fieldFunc(v[3]);
field[4] = fieldFunc(v[4]);
field[5] = fieldFunc(v[5]);
field[6] = fieldFunc(v[6]);
field[7] = fieldFunc(v[7]);
#endif
// recalculate flag
uint cubeindex;
cubeindex = uint(field[0] < isoValue);
cubeindex += uint(field[1] < isoValue)*2;
cubeindex += uint(field[2] < isoValue)*4;
cubeindex += uint(field[3] < isoValue)*8;
cubeindex += uint(field[4] < isoValue)*16;
cubeindex += uint(field[5] < isoValue)*32;
cubeindex += uint(field[6] < isoValue)*64;
cubeindex += uint(field[7] < isoValue)*128;
// find the vertices where the surface intersects the cube
#if USE_SHARED
// use shared memory to avoid using local
__shared__ float3 vertlist[12*NTHREADS];
vertlist[threadIdx.x] = vertexInterp(isoValue, v[0], v[1], field[0], field[1]);
vertlist[NTHREADS+threadIdx.x] = vertexInterp(isoValue, v[1], v[2], field[1], field[2]);
vertlist[(NTHREADS*2)+threadIdx.x] = vertexInterp(isoValue, v[2], v[3], field[2], field[3]);
vertlist[(NTHREADS*3)+threadIdx.x] = vertexInterp(isoValue, v[3], v[0], field[3], field[0]);
vertlist[(NTHREADS*4)+threadIdx.x] = vertexInterp(isoValue, v[4], v[5], field[4], field[5]);
vertlist[(NTHREADS*5)+threadIdx.x] = vertexInterp(isoValue, v[5], v[6], field[5], field[6]);
vertlist[(NTHREADS*6)+threadIdx.x] = vertexInterp(isoValue, v[6], v[7], field[6], field[7]);
vertlist[(NTHREADS*7)+threadIdx.x] = vertexInterp(isoValue, v[7], v[4], field[7], field[4]);
vertlist[(NTHREADS*8)+threadIdx.x] = vertexInterp(isoValue, v[0], v[4], field[0], field[4]);
vertlist[(NTHREADS*9)+threadIdx.x] = vertexInterp(isoValue, v[1], v[5], field[1], field[5]);
vertlist[(NTHREADS*10)+threadIdx.x] = vertexInterp(isoValue, v[2], v[6], field[2], field[6]);
vertlist[(NTHREADS*11)+threadIdx.x] = vertexInterp(isoValue, v[3], v[7], field[3], field[7]);
__syncthreads();
#else
float3 vertlist[12];
vertlist[0] = vertexInterp(isoValue, v[0], v[1], field[0], field[1]);
vertlist[1] = vertexInterp(isoValue, v[1], v[2], field[1], field[2]);
vertlist[2] = vertexInterp(isoValue, v[2], v[3], field[2], field[3]);
vertlist[3] = vertexInterp(isoValue, v[3], v[0], field[3], field[0]);
vertlist[4] = vertexInterp(isoValue, v[4], v[5], field[4], field[5]);
vertlist[5] = vertexInterp(isoValue, v[5], v[6], field[5], field[6]);
vertlist[6] = vertexInterp(isoValue, v[6], v[7], field[6], field[7]);
vertlist[7] = vertexInterp(isoValue, v[7], v[4], field[7], field[4]);
vertlist[8] = vertexInterp(isoValue, v[0], v[4], field[0], field[4]);
vertlist[9] = vertexInterp(isoValue, v[1], v[5], field[1], field[5]);
vertlist[10] = vertexInterp(isoValue, v[2], v[6], field[2], field[6]);
vertlist[11] = vertexInterp(isoValue, v[3], v[7], field[3], field[7]);
#endif
// output triangle vertices
uint numVerts = tex1Dfetch(numVertsTex, cubeindex);
for (int i=0; i<numVerts; i+=3)
uint index = numVertsScanned[voxel] + i;
float3 *v[3];
uint edge;
edge = tex1Dfetch(triTex, (cubeindex*16) + i);
#if USE_SHARED
v[0] = &vertlist[(edge*NTHREADS)+threadIdx.x];
#else
v[0] = &vertlist[edge];
#endif
edge = tex1Dfetch(triTex, (cubeindex*16) + i + 1);
#if USE_SHARED
v[1] = &vertlist[(edge*NTHREADS)+threadIdx.x];
#else
v[1] = &vertlist[edge];
#endif
edge = tex1Dfetch(triTex, (cubeindex*16) + i + 2);
#if USE_SHARED
v[2] = &vertlist[(edge*NTHREADS)+threadIdx.x];
#else
v[2] = &vertlist[edge];
#endif
// calculate triangle surface normal
float3 n = calcNormal(v[0], v[1], v[2]);
if (index < (maxVerts - 3))
pos[index] = make_float4(*v[0], 1.0f);
norm[index] = make_float4(n, 0.0f);
pos[index+1] = make_float4(*v[1], 1.0f);
norm[index+1] = make_float4(n, 0.0f);
pos[index+2] = make_float4(*v[2], 1.0f);
norm[index+2] = make_float4(n, 0.0f);
// sample volume data set at a point
__device__
float sampleVolume(uchar *data, uint3 p, uint3 gridSize)
p.x = min(p.x, gridSize.x - 1);
p.y = min(p.y, gridSize.y - 1);
p.z = min(p.z, gridSize.z - 1);
uint i = (p.z*gridSize.x*gridSize.y) + (p.y*gridSize.x) + p.x;
// return (float) data[i] / 255.0f;
return tex1Dfetch(volumeTex, i);
Thanks a lot for your help !!
