I am testing out the possibility of swinging thrust’s backend between CUDA, OpenMP and TBB. However, when I tried it with Thrust/OpenMP backend, there are a lot of warnings:
[ 50%] Building NVCC (Device) object CMakeFiles/test.dir/test_generated_test.cu.o
In file included from /usr/local/cuda-9.1/include/thrust/system/cuda/detail/execution_policy.h:31:0,
from /usr/local/cuda-9.1/include/thrust/system/cuda/detail/util.h:33,
from /usr/local/cuda-9.1/include/thrust/system/cuda/detail/terminate.h:31,
from /usr/local/cuda-9.1/include/thrust/detail/allocator/temporary_allocator.inl:24,
from /usr/local/cuda-9.1/include/thrust/detail/allocator/temporary_allocator.h:84,
from /usr/local/cuda-9.1/include/thrust/detail/temporary_array.h:27,
from /usr/local/cuda-9.1/include/thrust/detail/overlapped_copy.h:23,
from /usr/local/cuda-9.1/include/thrust/detail/vector_base.inl:24,
from /usr/local/cuda-9.1/include/thrust/detail/vector_base.h:547,
from /usr/local/cuda-9.1/include/thrust/device_vector.h:26,
from /home/qth20/Documents/thrust_cuda_test/test.cu:1:
/usr/local/cuda-9.1/include/thrust/system/cuda/config.h:77:0: warning: "THRUST_CUB_NS_PREFIX" redefined
#define THRUST_CUB_NS_PREFIX namespace thrust { namespace cuda_cub {
In file included from /usr/local/cuda-9.1/include/thrust/system/cuda/detail/cub/util_arch.cuh:36:0,
from /usr/local/cuda-9.1/include/thrust/system/cuda/detail/util.h:32,
/usr/local/cuda-9.1/include/thrust/system/cuda/detail/cub/util_namespace.cuh:41:0: note: this is the location of the previous definition
/usr/local/cuda-9.1/include/thrust/system/cuda/config.h:78:0: warning: "THRUST_CUB_NS_POSTFIX" redefined
#define THRUST_CUB_NS_POSTFIX } }
/usr/local/cuda-9.1/include/thrust/system/cuda/detail/cub/util_namespace.cuh:45:0: note: this is the location of the previous definition
[100%] Linking CXX executable test
[100%] Built target test
Here is my CMakeLists.txt:
PROJECT(test)
set (OUTPUT_NAME test)
cmake_minimum_required (VERSION 2.8)
#test variable
#set(THRUST_DEVICE_SYSTEM THRUST_DEVICE_SYSTEM_CUDA)
set(THRUST_DEVICE_SYSTEM THRUST_DEVICE_SYSTEM_OMP)
#set(THRUST_DEVICE_SYSTEM THRUST_DEVICE_SYSTEM_TBB)
# Set CUDA
find_package(CUDA REQUIRED)
list(APPEND CUDA_NVCC_FLAGS -gencode arch=compute_70,code=sm_70)
list(APPEND CUDA_NVCC_FLAGS -DTHRUST_DEVICE_SYSTEM=${THRUST_DEVICE_SYSTEM})
list(APPEND CUDA_NVCC_FLAGS -Xcompiler -fopenmp)
set (sources_gpu_cuda test.cu)
# Set OpenMP
set(omp_deps gomp)
set (sources ${sources_gpu_cuda})
cuda_add_executable(${OUTPUT_NAME} ${sources} ${headers})
target_link_libraries (${OUTPUT_NAME} ${omp_deps})
And file test.cu:
#include <thrust/device_vector.h>
#include <cstdio>
struct cuda_hello
__host__ __device__
void operator()(int x)
printf("Hello, world from Cuda!\n");
int main()
thrust::device_vector<int> cuda_vec(1, 0);
thrust::for_each(cuda_vec.begin(),cuda_vec.end(),cuda_hello());
Doesn’t look like I violate anything - as in the code still compiled and run normally. I just want to know what these warning means. This is CUDA 9.1 compiled with gcc 6.4.0.
