Cuda with 9800 GX2 on Vista 32 driver problems What's the approved fix?
I have a 9800 GX2 in a Vista 32 machine. I tried to install the latest 177.35 driver from the CUDA download page but I get a similar problem to many others:
The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit.
In my research I’ve seen people suggest several different versions of drivers (177.55, 174.55, etc.) all requiring an inf mod. My question is: what is the real solution to this problem?
Hi Revane,
Try to look for the drivers provided by your motherboard maker could help. In my case, I got the same error with my Dell Latitute D830. After got the driver from Dell web site, the problem was solved.
