CUDA with OpenMPI on Ubuntu 8.04
This is a pretty random question, but here it goes…
I am attempting to integrate mpi code into my CUDA enabled program. The goal is to offload background processes to a separate box that I have (2x Tesla cards) rather than trying to fit more GPU cores into my current box (3x 280). The internal gigabit network is set up and I can execute simple openmpi programs (hello world -ish) across the network without any problems. When I try to execute my full CUDA utilizing program, I get the following error.
program: error while loading shared libraries: libcudart.so.2: cannot open shared object file: No such file or directory
The program itself can run on each machine without any problems (i.e. mpirun -np 1 program). I only run into trouble with (mpirun -np 2 -machinefile hostnames program) Any thoughts or suggestions?
My setup
Computer 1
3x 280
Computer 2
9500 + 2x Tesla
Both computers have:
quad core AMD
8GB RAM
Ubuntu 8.04
Undoubtedly environment. You will need to pass LD_LIBRARY_PATH settings to the process on the remote machine. The mpirun/mpiexec manpage should hold all the answers you need.
avidday… thanks for your help. For anyone who may have this problem in the future, here is the command line that runs everything flawlessly
mpirun -np 2 -machinefile hostfile -x LD_LIBRARY_PATH program_name
