I have a server with Windows 2008 R2 Enterprise (64 bit, of course). The server is equipped with Quadro 4000 (Fermi).
I’ve installed:
Quadro/Tesla Driver v275.65 WHQL
CUDA Toolkit 4.0
GPU Computing SDK 4.0
The graphics card runs just fine; I can see it listed in Device Manager.
I’m connecting to server via RDC. When I try to run the bandwidthTest.exe I’m getting the following output:
CUDA Device Query (Runtime API) version (CUDART static linking)
Found 1 CUDA Capable device(s)
Device 0: “Quadro 4000”
CUDA Driver Version / Runtime Version 4.0 / 4.0
CUDA Capability Major/Minor version number: 2.0
Total amount of global memory: 2048 MBytes (2147024896 bytes)
( 8) Multiprocessors x (32) CUDA Cores/MP: 256 CUDA Cores
GPU Clock Speed: 0.95 GHz
Memory Clock rate: 1404.00 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65535), 3D=(2048,2048,2048)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: Yes
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 16 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 4.0, CUDA Runtime Version = 4.0, NumDevs = 1, Device = Quadro 4000
[deviceQuery.exe] test results…
PASSED
