cuda x86 compile error
Hi,I’m new to CUDA x86.When I compile the cu file with the command
“pgcpp -c -O -Mcudax86 cuConvolution.cu”
(Win7 64bit)
,error message is below:
“C:\PROGRA~1\PGI/win64/2015/cuda/6.0/include/surface_functions.h”, line 571: error:
no instance of overloaded function “surf2Dread” matches the
specified type
forceinline device short4 surf2Dread(surface<void, cudaSurfaceType2D>
surf, int x, int y, enum cudaSurfaceBoundaryMode mode).
The cu file code is
#include "cuConvolution.h"
int cuConvolution()
	int nRet = ERR_SUCCESS;
	return nRet;
The header file code is
#ifndef GPU_CONV_H
#define GPU_CONV_H
#ifdef GPUDLLEXPORT
#define GPUEXPORT __declspec(dllexport)
#else
#define GPUEXPORT __declspec(dllimport)
#endif
int GPUEXPORT cuConvolution();
#endif
Can anyone gives me some advices?Thanks in advance.
From searching the forum,I know that cuda-x86 is no longer supported.Bad news!
Huipeng -
You are correct. We do not support Cuda-x86 on Windows,
and pgcpp on windows is being depecated.
-Deborah Caruso
