CUDA XLL
Hi
Im trying to create a really simple XLL using CUDA. I can compile the XLL just fine and it works however when I enable the CUDA files, even though their functions arent used, the XLL is no longer recognised even though it compiles OK
Ive traced the problem down to the two library files, cudart.lib and cutil32d.lib which are the additional dependencies in the XLL output even though they arent used
Does anyone know how to successfully create a XLL with CUDA inside?
Thanks in advance
G
Hi
Thanks in advance
G
