Today I installed CUDA3.0 toolkit, so that I have failed to compile error for “size_t” type.
“size_t” is ,according to specific doc, built-in scalar data type. Is it nVidia’s driver bug??
Could you paste some code? Where are you trying to use size_t?
thanks for replying.
I have tried to compile follow code.
[codebox]__kernel
void example(
__read_only image2d_t src,
__read_only image2d_t prd,
__global int* dst,
size_t pitch)
[/codebox]
then, i have failed with follow message.
[codebox]:xxx: error: __kernel function cannot have argument of type ‘size_t’
size_t pitch)
[/codebox]
Ah, see that’s illegal. You can’t use size_t as a kernel argument:
Chapter 6.8, point ‘k’
What to do instead then? Use uint, for example?
Yup. Make sure you don’t mess up word length (ex. with a 64 bit host and 32 bit device).
oops, I forgot this ristrictions. (but size_t can be used on previous OpenCL version.)
I’ gona use uint instead of size_t.
