I’m writing a plugin for a host application where I’m provided a cudaArray for incoming image data and another cudaArray (for which I have to make a surface) for outgoing image data.
What is the best way to get data to/from a NvVFX effect? I initially thought I could use NvCVImage_Init() to point to the incoming data (the cudaArray directly, trying to avoid a copy). It doesn’t seem to be able to read the data in cudaArray (as one would require), and I can’t use a surface since the type is wrong.
Now I’m copying from a cuda surface to a previously allocated NvCVImage running an effect. Then I copy the outgoing NvCVImage (previously allocated) back to another surface.
A couple of things:
I can’t seem to use any built-in cudaMemcpy functions, so I have to use a custom kernel for both copies. Is there something I’m missing?
Does the first copy really need to happen, or the last? Since all data is accessed and modified via CUDA, it seems I should be able to at least read the source data directly in the effect.
Are there any suggestions on how to properly read/write NvCVImage from/to cuda surfaces/cudaArrays?
Real-time performance is a big factor, so it would be ideal to avoid as much copying and overhead as possible
Thanks,
Keith
