CUDACasts Episode 20: Getting started with Jetson TK1 and OpenCV
Originally published at: https://developer.nvidia.com/blog/cudacasts-episode-20-getting-started-jetson-tk1-opencv/
The Jetson TK1 development kit has fast become a must-have for mobile and embedded parallel computing due the amazing level of performance packed into such a low-power board. In this and the following CUDACast, you’ll learn how to get started building computer vision applications on your Jetson TK1 using CUDA and the OpenCV library. CUDACasts…
Awesome, thanks!
I just installed JetPack 2.3 Isn't OpenCV included in the Jetpack? If so, how do I make use of it?
Where does the folder "bgfg" come from and how did you run that sample? I don't have that folder. How would I find and try this same sample?
