cudaDeviceProp undeclared (first use in this function)
hi, i have some problems when i try compile a program that uses this function.
i have a .cu file where i have one function that use the function and another file .c where i call the .cu function.
nvcc -o projecto.o -c -arch=sm_11 -O3 -I. projecto.cu
gcc main.c `pkg-config libglade-2.0 gtk+-2.0 --cflags` `pkg-config libglade-2.0 gtk+-2.0 --libs` -Wl,-export-dynamic projecto.o -I/usr/local/cuda/include -I/home/pinto/NVIDIA_CUDA_SDK/common/inc -L/usr/local/cuda/lib -L/home/pinto/NVIDIA_CUDA_SDK/lib -L/home/pinto/NVIDIA_CUDA_SDK/common/lib -lcuda -lcudart -lcutil -lm -lmpich
ERROR:
projecto.cu: In function âgpu_infoâ:
projecto.cu:44: error: âcudaDevicePropâ undeclared (first use in this function)
projecto.cu:44: error: (Each undeclared identifier is reported only once
projecto.cu:44: error: for each function it appears in.)
projecto.cu:44: error: expected â;â before âdevicePropâ
LINE 44:
cudaDeviceProp deviceProp;
Did you include the correct headers?
#include <cuda.h>
#include <cuda_runtime_api.h>
N.
yes, i include in both
projecto.cu
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <cuda.h>
main.c
#include <gtk/gtk.h>
#include <glade/glade.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <time.h>
#include <math.h>
#include <cuda.h>
#include "projecto.cu"
Take a look at the deviceQuery project in the SDK and see what you’re doing differently…
N.
Hi, i up this topic because i have the same problem,
how can i resolve it?
try including builtin_types.h
That will get you all the types that the runtime library uses.
I tried this without any result.
Buf i found one thing : i was compiling my C code with gcc and i got the undeclared error.
Now, compiling with g++ works (exactly same code, same includes and same flags). And the code can be run without problem.
gcc version used : gcc version 4.1.2 20080704 (Red Hat 4.1.2-46)
[display problem, no need of a new message, sorry]
Hey,
i got the same compiler error. In fact compiling the code with g++ solves this error. For everyone, who wants to use a c-only compiler … after some time of searching for the declaration of cudaDeviceProp i found the following solution:
#ifdef __cplusplus
#else // !_cplusplus
   struct cudaDeviceProp deviceProp;
#endif
which solved the problem for me !
hope that helps, cheerz !
