cudaError_enum error with Quadro NVS 140M
Hi all,
  I am a newbie to CUDA and was experimenting with the matrix addition program. I got a Thinkpad T61 which comes with the Quadro NVS 140M. I allocate a small amount of mem which imho will be supported by the NVS since its 128 meg. However, I still get the cudaError_enum error no matter what I change the size of the matrix to be.
 const int N = 8;
  const int blocksize = 2;
   const int size = N*N*sizeof(float);
    CUDA_SAFE_CALL ( cudaMalloc( (void**)&ad, size));
    CUDA_SAFE_CALL ( cudaMalloc( (void**)&bd, size));
    CUDA_SAFE_CALL ( cudaMalloc( (void**)&cd, size));
   CUDA_SAFE_CALL ( cudaMemcpy(ad, a, size, cudaMemcpyHostToDevice));
    CUDA_SAFE_CALL ( cudaMemcpy(bd, b, size, cudaMemcpyHostToDevice));
   dim3 dimBlock( blocksize, blocksize);
    dim3 dimGrid (N/dimBlock.x, N/dimBlock.y);
    add_matrix<<<dimGrid, dimBlock>>>(ad, bd, cd, N);
   CUDA_SAFE_CALL ( cudaMemcpy(c, cd, size, cudaMemcpyDeviceToHost));
   CUDA_SAFE_CALL ( cudaFree(ad));
    CUDA_SAFE_CALL ( cudaFree(bd));
    CUDA_SAFE_CALL ( cudaFree(cd));
I get the error in all the lines above where memory is being allocated. I will also paste my deviceQuery result just for information sake.
There is 1 device supporting CUDA
Device 0: “Quadro NVS 140M”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 133890048 bytes
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 800000 kilohertz
Test PASSED
Press ENTER to exit…
I would really appreciate it if somebody can tell me where I am going wrong. I use the latest version of the graphics driver which comes with CUDA 2.0 yet I use CUDA 1.1 for this.
Just noticed that even the example programs throw out the same cudaError_enum when I am running it.
