Here is an example about i want to do:
struct datastruct { int data1, int* data2 }; datastruct* Dev_dtstrct; CudaMalloc(Dev_dtstrct.....); ... ... ... //Free the device memory after usage CudaFree(Dev_dtstrct);
Will the CudaFree also free the data2 pointer inside the structure?
Regards
Abdoulaye
it will not.
The behavior is similar to host code usage of C-standard malloc and free. If you had an instance of a struct like that in host allocated memory, and you used free on the pointer, it would not free any embedded pointers/allocations.
malloc
free
Alright ! Thanks
