On a Windows 10 box, with Cuda 8.0.61 installed, cudaGetDeviceCount() returns 0 with the error code 38 (cudaErrorNoDevice).
Below, the raw output obtained by running “nvidia-smi.exe -a”.
I am bit baffled by the error, because the two GPUs are working fine, but they just aren’t seen by Cuda.
Does anyone know how I could fix the problem?
Joannes
==============NVSMI LOG==============
Timestamp : Fri Jun 30 12:12:53 2017
Driver Version : 382.05
Attached GPUs : 2
GPU 0000:01:00.0
Product Name : GeForce GTX 960M
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-xxx
Minor Number : N/A
VBIOS Version : 82.07.82.00.22
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x139B10DE
Bus Id : 0000:01:00.0
Sub System Id : 0x06E41028
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P8
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Sync Boost : Not Active
Unknown : Not Active
FB Memory Usage
Total : 2048 MiB
Used : 28 MiB
Free : 2020 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 225 MiB
Free : 31 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 50 C
GPU Shutdown Temp : 101 C
GPU Slowdown Temp : 96 C
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 405 MHz
SM : 405 MHz
Memory : 405 MHz
Video : 405 MHz
Applications Clocks
Graphics : 1032 MHz
Memory : 2505 MHz
Default Applications Clocks
Graphics : 1032 MHz
Memory : 2505 MHz
Max Clocks
Graphics : 1202 MHz
SM : 1202 MHz
Memory : 2505 MHz
Video : 1081 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
GPU 0000:0B:00.0
Product Name : GeForce GTX 1080 Ti
Display Mode : Enabled
Display Active : Enabled
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : xxx
GPU UUID : GPU-xxx
Minor Number : N/A
VBIOS Version : 86.02.39.00.01
MultiGPU Board : No
Board ID : 0xb00
GPU Part Number : 900-1G611-0050-000
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x0B
Device : 0x00
Domain : 0x0000
Device Id : 0x1B0610DE
Bus Id : 0000:0B:00.0
Sub System Id : 0x85E21043
GPU Link Info
PCIe Generation
Max : 3
Current : 2
Link Width
Max : 16x
Current : 4x
Bridge Chip
Type : N/A
Firmware : N/A
Tx Throughput : 11000 KB/s
Rx Throughput : 21000 KB/s
Fan Speed : 23 %
Performance State : P5
Idle : Not Active
FB Memory Usage
Total : 11264 MiB
Used : 283 MiB
Free : 10981 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 229 MiB
Free : 27 MiB
Utilization
Gpu : 22 %
Memory : 9 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Pending : N/A
Temperature
GPU Current Temp : 32 C
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 93 C
Power Readings
Power Management : Supported
Power Draw : 19.17 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 125.00 W
Max Power Limit : 300.00 W
Clocks
Graphics : 670 MHz
SM : 670 MHz
Memory : 810 MHz
Video : 734 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 5505 MHz
Video : 1708 MHz
Clock Policy
Auto Boost : N/A
Processes
Process ID : 2216
Type : C+G
Name : Insufficient Permissions
Used GPU Memory : Not available in WDDM driver model
Process ID : 8128
Type : C+G
Name : C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\devenv.exe
