hi,
Firstly i started using cuda beta 0.8 in Fedora 6. i am using a nvidia geforce 8800 gtx card. after installing both cuda and sdk, i tried to compile the sample programs. but it was giving some error. am using linux driver 1.0-9755.
Now i am using RHEL ES release 4. now the programs are compiled without any errors… but when i run them most of the programs fails…
i have also tried my hand on device managemet programs… it looks like below-----
#include<stdio.h>
int main(int argc, char** argv)
int ct,dev;
struct cudaDeviceProp prop;
cudaGetDeviceCount(&ct);
if(ct == 0)
printf("\nNo Device Found\n");
exit(0);
else
printf("\n%d Device Found\n",ct);
cudaGetDevice(&dev);
printf("\nThe Device ID is %d\n",dev);
cudaGetDeviceProperties(&prop,dev);
printf("\nThe Properties of the Device with ID %d are\n",dev);
printf("\tDevice Name : %s",prop.name);
printf("\n\tDevice Memory Size (in bytes) : %u",prop.bytes);
printf("\n\tDevice Major Revision Numbers : %d",prop.major);
printf("\n\tDevice Minor Revision Numbers : %d",prop.minor);
printf("\n");
and the ouput is as below…
1 Device Found
The Device ID is 0
The Properties of the Device with ID 0 are
Device Name : GeForce 8800 GTX
Device Memory Size (in bytes) : 0
Device Major Revision Numbers : 1
Device Minor Revision Numbers : 0
Here all other functions give the correct results.... only the device memory is showing 0.
can any body guide me in this regard …
thanks…
farid khan
