Because you have a global variable (maybe a texture) that uses the same name in multiple compilation units. Don’t do that because it breaks CUDART in a really bad way (and always had, you were probably just getting lucky before).
That is strange because when I remove the checkerror call, the program runs fine without hickups.
I did not find this error message in the enum error types in the new reference manual.
I like to chose my variable names as freely as I can.
It is not enough to add static in front of all device calls.
You have to eliminate the real duplicate variables left in your functions.
I did not ran my program for a long time enough to find that there was another duplicated variable left despite the static attribute.
It would help a lot if the message would point to the faulty variable.
