I would like to use 2 variables to get the maximum values of an image but there is a proble.
Here is the code:
__device__ unsigned int i_MinImage;
__device__ unsigned int i_MaxImage;
void* ptr_min;
void* ptr_max;
cudaGetSymbolAddress((void **)&ptr_min, i_MinImage);
cudaGetSymbolAddress((void **)&ptr_max, i_MaxImage);
cudaMemset(ptr_min, 10, sizeof(int));
cudaMemset(ptr_max, -10, sizeof(int));
int iMin_host,iMax_host;
cudaDeviceSynchronize();
cudaMemcpy(&iMin_host, &ptr_min, sizeof(int), cudaMemcpyDeviceToHost);
cudaMemcpy(&iMax_host, &ptr_max, sizeof(int), cudaMemcpyDeviceToHost);
I know that the code is doing nothing really interesting but I would like to show you my problem.
I just do a write and read variables from GPU. My Min_host/Max_host variable should be 10/-10 but I get a strange variables 16840000, …
I don’t understand why this append. I do other process like sobel filtering, and all works properly but this part send me back wrong data.
