cudaGraphicsGLRegisterBuffer returns cudaErrorOperatingSystem when called from a DLL
I’m trying to make a DLL using cuda and openGL to create on screen rendering DLL. I have been using the simpleGL sample. the sample is working completely fine but when I’m trying to implement it inside my DLL I get cudaErrorOperatingSystem from cudaGraphicsGLRegisterBuffer function which is being called in kernal.cu. I am using visual studio 2022 on a windows 11 operating system and cuda 12.0.
CR.cpp
#define GLEW_STATIC
#include "GL/glew.h"
#include "GLFW/glfw3.h"
#include "CR.h"
#include "pch.h"
#include "Kernal.h"
#include <string>
CR::CR(){}
CR::~CR(){}
CR_ERROR CR::createWindow(unsigned int x, unsigned int y, const char* title){
    maxX = x; maxY = y;
    if (glfwInit() != GLFW_TRUE)
        return CR_WINDOW_INIT_FAILED;
    glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
    glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
    glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
    wnd = (void*)glfwCreateWindow(x, y, title, nullptr, nullptr);
    if ((GLFWwindow*)wnd == NULL)
    glfwMakeContextCurrent((GLFWwindow*)wnd);
    if (glewInit() != GLEW_OK)
    glClearColor(1,1,1,1);
    glGenVertexArrays(1,&vao);
    glBindVertexArray(vao);
    glGenBuffers(1, &vbo);
    glBindBuffer(GL_ARRAY_BUFFER, vbo);
    size_t size = x * y * 4 * sizeof(float);
    glBufferData(GL_ARRAY_BUFFER, size, 0, GL_DYNAMIC_DRAW);
    glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, 3 * sizeof(float), (void*)0);
    glEnableVertexAttribArray(0);
    k = (void*)new Kernal(&vbo);
    return CR_OK;
void CR::display() {
    while (!glfwWindowShouldClose((GLFWwindow*)wnd))
        /* Render here */
        glClear(GL_COLOR_BUFFER_BIT);
        ((Kernal*)k)->runCuda(maxX,maxY);
        /* Swap front and back buffers */
        glfwSwapBuffers((GLFWwindow*)wnd);
        /* Poll for and process events */
        glfwPollEvents();
CR.h:
#pragma once
#ifdef CR_EXPORT
#define CR_API __declspec(dllexport)
#else
#define CR_API __declspec(dllimport)
#endif
enum CR_ERROR {
    CR_OK,
    CR_WINDOW_INIT_FAILED,
class CR_API CR {
public:
    CR();
    ~CR();
    CR_ERROR createWindow(unsigned int x, unsigned int y, const char* title);
    void display();
private:
    unsigned int maxX, maxY;
    unsigned int vbo, vao;
    void* wnd;
    void* k;
kernal.cu:
#include "kernal.h"
#include <string>
#define checkError(err) checkForCudaErrors(err,__LINE__)
void checkForCudaErrors(cudaError_t err,int line) {
    if (err != cudaSuccess) {
        std::string error = cudaGetErrorString(err);
        error += " on line: ";
        error += std::to_string(line);
        MessageBoxExA(NULL,error.c_str(), NULL, MB_OK | MB_ICONERROR, MAKELANGID(LANG_NEUTRAL, SUBLANG_NEUTRAL));
__global__ void drawCircle(float3* pos, size_t size, int x, int y, int r, int maxX, int maxY) {
    for (int i = blockDim.x * blockIdx.x + threadIdx.x; i < maxX; i += blockDim.x * gridDim.x) {
        for (int j = blockDim.y * blockIdx.y + threadIdx.y; j < maxY; j += blockDim.y * gridDim.y) {
            if (x * x + y * y < r * r)
                pos[maxX * y + x] = make_float3(1, 0, 0);
void Kernal::drawCircleCaller(unsigned int x, unsigned int y, unsigned int r, unsigned int maxX, unsigned int maxY) {
    dim3 threads(16, 16);
    dim3 blocks(maxX / 16 + 1, maxY / 16 + 1);
    drawCircle << < blocks, threads >> > (pos,size, x, y, r, maxX, maxY);
    checkError(cudaDeviceSynchronize());
    checkError(cudaGetLastError());
Kernal::Kernal(unsigned int* vbo) : vbo{ vbo } {
    checkError(cudaGraphicsGLRegisterBuffer(&vboResource, *vbo, cudaGraphicsRegisterFlagsNone));
void Kernal::runCuda(unsigned int maxX, unsigned int maxY){
    checkError(cudaGraphicsMapResources(1, &vboResource, 0));
    checkError(cudaGraphicsResourceGetMappedPointer((void**)&pos, &size, vboResource));
    drawCircleCaller(100, 100, 50, maxX, maxY);
    cudaGraphicsUnmapResources(1, &vboResource, 0);
I tried using cuda 11.7 which I have installed but the error still occurs.
Hi @nivrazon, welcome to the NVIDIA developer forums!
I think to figure out the best way to correctly build and link a CUDA app into a DLL, th eCUDA programming forums will be more helpful to you.
I hope you don’t mind me moving your post over.
