I am porting an aeroacoustics code that is using MPI/OpenMP/Accelerator to use MPI/OpenMP/CUDA Fortran. To simplify the process, I am using the CUF kernel loop directive in the following subroutine:
subroutine cuda_surfaces (surface_accel,surf_x_ip,surf_x_im,surf_y_jp,surf_y_jm)
use accel
use cudafor
double precision, dimension (0:i_max_accel+1,0:j_max_accel+1,4), intent (in), device :: surface_accel
double precision, dimension (0:i_max_accel+1,0:j_max_accel+1), intent (out), device :: surf_x_ip,surf_x_im,surf_y_jp,surf_y_jm
integer :: i,j
!$cuf kernel do(2) <<< (*,*), (n_cores_smp,nu_smps_gpu) >>>
do j=0,j_max_accel+1
do i=0,i_max_accel+1 !line 2161:cudaLaunch returned status 4
surf_x_ip(i,j)=surface_accel(i,j,1)
surf_x_im(i,j)=surface_accel(i,j,2)
surf_y_jp(i,j)=surface_accel(i,j,3)
surf_y_jm(i,j)=surface_accel(i,j,4)
end do
end do
end subroutine cuda_surfaces
where the accel module is given by:
module accel
integer, parameter :: n_cores_smp=32
integer, parameter :: nu_smps_gpu=14
integer, parameter :: i_max_accel=2336
integer, parameter :: j_max_accel=1624
end module accel
Subroutine cuda_surfaces is called by subroutine euler_solver, where the related parts are:
subroutine euler_solver (....)
use accel
use cudafor
double precision, dimension (0:i_max_accel+1,0:j_max_accel+1,4) :: surface_host
double precision, dimension (0:i_max_accel+1,0:j_max_accel+1,4), device :: surface_accel
double precision, dimension (0:i_max_accel+1,0:j_max_accel+1), device :: surf_x_ip,surf_x_im,surf_y_jp,surf_y_jm,vol
call mpi_barrier (mpi_comm_world,ierr)
!setting the number of threads for the following openmp parallel region equal to the number of gpus
call omp_set_num_threads(n_threads_gpus)
!$omp parallel, private (surface_accel,surf_x_ip,surf_x_im,surf_y_jp,surf_y_jm)
devnum=omp_get_thread_num()
istat=cudaSetDevice(devnum)
!$omp do
do l_block=1,l_max_block !block size is i_max_accel*j_max_accel
surface_accel=surface_host
call cuda_surfaces (surface_accel,surf_x_ip,surf_x_im,surf_y_jp,surf_y_jm)
end do
!$omp end do
!$omp end parallel
return
end subroutine euler_solver
When I try to run the code, I get the following error message:
line 2161: cudaLaunch returned status 4: unspecified launch failure
where line 2161 is shown commented in subroutine cuda_surfaces and corresponds to the innermost loop. The compilation message related to this subroutine is:
cuda_surfaces:
2161, CUDA kernel generated
2161, !$cuf kernel do <<< (*,*), (32,14) >>>
Any help will be appreciated.
Regards,
Roberto
