Hi all,
I am new at cuda programming. I am working on a project for parallelizing a sequential program.
I began using the cuda 2.3 version on a GPU X295 card. Then I obtained an access to a server with a Fermi card with cuda 3.0 on it.
When I try to run my program on this server with Fermi on it, I have a segmentation fault on the first cudaMalloc of the program.
I have tried some simple programs and they run well on the Fermi.
The messages I have from cuda-gdb are:
Breakpoint 1, cuda_allocation () at kernel.cu:133
133
size_mat=mat_length_max*VProd(cells)*sizeof(int);
Current language: auto; currently c++
(cuda-gdb) n
134 size_site=nSites*sizeof(Site);
(cuda-gdb)
135 size_neigh=nebrTabMax*sizeof(int);
(cuda-gdb)
136 size_nebrEl=nSites*sizeof(int);
(cuda-gdb)
137 size_inertia = nTypes;
(cuda-gdb)
138 size_massDev = nTypes;
(cuda-gdb)
140 size_interactionTypeDev1 = nebrTabMax;
(cuda-gdb)
141 size_sigDev = nTypes*nTypes;
(cuda-gdb)
142 size_epsDev = nTypes*nTypes;
(cuda-gdb)
143 size_productElectroMomentsDev = nTypes*nTypes;
(cuda-gdb)
145 widthTex = ceil(sqrt(nSites));
(cuda-gdb)
147 channelDesc_V = cudaCreateChannelDesc();
(cuda-gdb)
149 cudaMalloc((void**)&mat, size_mat);
(cuda-gdb)
Segmentation fault
The program runs normally (I guess with an accentuated latency), only when I set the -G options te the nvcc Cuda compilator, otherwise it fails with a segmentation fault exactly in the lines I described above.
I paste here what is written in the core generated from the failure of the program:
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type “show copying”
and “show warranty” for details.
This GDB was configured as “x86_64-linux-gnu”.
For bug reporting instructions, please see:
http://www.gnu.org/software/gdb/bugs/…
Reading symbols from /home/shkurti/Prove/13000configuration/program…done.
[New Thread 13970]
warning: Can’t read pathname for load map: Input/output error.
Reading symbols from /lib/libm.so.6…Reading symbols from /usr/lib/debug/lib/libm-2.11.1.so…done.
done.
Loaded symbols for /lib/libm.so.6
Reading symbols from /usr/lib/libcuda.so.1…(no debugging symbols found)…done.
Loaded symbols for /usr/lib/libcuda.so.1
Reading symbols from /usr/local/cuda/lib64/libcudart.so.3…(no debugging symbols found)…done.
Loaded symbols for /usr/local/cuda/lib64/libcudart.so.3
Reading symbols from /lib/libc.so.6…Reading symbols from /usr/lib/debug/lib/libc-2.11.1.so…done.
done.
Loaded symbols for /lib/libc.so.6
Reading symbols from /usr/lib/libstdc++.so.6…(no debugging symbols found)…done.
Loaded symbols for /usr/lib/libstdc++.so.6
Reading symbols from /lib/libpthread.so.0…Reading symbols from /usr/lib/debug/lib/libpthread-2.11.1.so…done.
done.
Loaded symbols for /lib/libpthread.so.0
Reading symbols from /lib/libz.so.1…(no debugging symbols found)…done.
Loaded symbols for /lib/libz.so.1
Reading symbols from /lib/libdl.so.2…Reading symbols from /usr/lib/debug/lib/libdl-2.11.1.so…done.
done.
Loaded symbols for /lib/libdl.so.2
Reading symbols from /lib/librt.so.1…Reading symbols from /usr/lib/debug/lib/librt-2.11.1.so…done.
done.
Loaded symbols for /lib/librt.so.1
Reading symbols from /lib/libgcc_s.so.1…(no debugging symbols found)…done.
Loaded symbols for /lib/libgcc_s.so.1
Reading symbols from /lib64/ld-linux-x86-64.so.2…Reading symbols from /usr/lib/debug/lib/ld-2.11.1.so…done.
done.
Loaded symbols for /lib64/ld-linux-x86-64.so.2
Core was generated by `./program’.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f75a7ae555e in ?? () from /usr/lib/libcuda.so.1
(gdb) bt
#1 0x00007f75a7aea99e in ?? () from /usr/lib/libcuda.so.1
#2 0x00007f75a7afdecd in ?? () from /usr/lib/libcuda.so.1
#3 0x00007f75a7b03729 in ?? () from /usr/lib/libcuda.so.1
#4 0x00007f75a7b048b5 in ?? () from /usr/lib/libcuda.so.1
#5 0x00007f75a7b07ee4 in ?? () from /usr/lib/libcuda.so.1
#6 0x00007f75a7b08e2a in ?? () from /usr/lib/libcuda.so.1
#7 0x00007f75a7b0921c in ?? () from /usr/lib/libcuda.so.1
#8 0x00007f75a7c69120 in ?? () from /usr/lib/libcuda.so.1
#9 0x00007f75a7c831db in ?? () from /usr/lib/libcuda.so.1
#10 0x00007f75a794d082 in ?? () from /usr/lib/libcuda.so.1
#11 0x00007f75a78c1f75 in ?? () from /usr/lib/libcuda.so.1
#12 0x00007f75a79020a6 in ?? () from /usr/lib/libcuda.so.1
#13 0x00007f75a78c1c55 in ?? () from /usr/lib/libcuda.so.1
#14 0x00007f75a78c13ed in ?? () from /usr/lib/libcuda.so.1
#15 0x00007f75a78baf91 in ?? () from /usr/lib/libcuda.so.1
#16 0x00007f75a7773d2a in ?? () from /usr/lib/libcuda.so.1
#17 0x00007f75a775bb29 in ?? () from /usr/lib/libcuda.so.1
#18 0x00007f75a7804ab9 in ?? () from /usr/lib/libcuda.so.1
#19 0x00007f75a74b51ce in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#20 0x00007f75a74aabdb in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#21 0x00007f75a74af00c in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#22 0x00007f75a74a8f89 in cudaMalloc () from /usr/local/cuda/lib64/libcudart.so.3
#23 0x000000000043682f in cuda_allocation ()
#24 0x0000000000407aa1 in main (argc=1, argv=0x7fff93e07cc8) at main.c:266
Does anybody have any idea about how can I set right this kind of problem?
