I ran into some difficulties while trying to copy a 3D volume of integer values from device to host. While debugging the code I noticed a weird value was attributed to the xsize field of the cudaPitchedPtr struct that cudaMalloc3D returns.
int width = 434;
int height = 383;
int depth = 20;
cudaPitchedPtr pitchedPointer;
cudaExtent extent = make_cudaExtent(width*sizeof(int),height, depth);
cudaMalloc3D(&pitchedPointer, extent);
The values returned in pitchedPointer are:
pitchedPointer.pitch → 2048
seems ok; a row is alligned to be of 512 elemens in width, multiplied by sizeof(int) which is 4 => 2048
pitchedPointer.ysize → 383 also ok
pitchedPointer.xsize → 1736
not ok; according to the Reference Manual (v 4.0) pg. 50:
However, it seems that xsize is returned in bytes 1736 = sizeof(int)*434.
Basically when I try a cudaMemcpy3D from device to host if i do not manually modify the pitchedPointer.xsize to be 434 the values I get are completely messed up.
Anybody else noticed this problem? Or am I making some wrong judgement? Because, if not, I will file this as a bug report… :)
