cudaMalloc'ed pointer should have global scope, but doesn't?
Hi All,
I’m trying to incorporate CUDA into an existing C project. I have a problem with the cudaMalloc’ed pointer getting lost. Here’s a trimmed-down version of the problem:
Makefile
LIBS = -lcudart_static
LFLAGS = -L /Developer/NVIDIA/CUDA-6.5/lib
CUDAINC = -I /Developer/NVIDIA/CUDA-6.5/include
CFLAGS = -Xcompiler="-g, -O0, -Wall, -Wshadow, -Wno-deprecated, -arch x86_64"
PCLOBJ = DbgMain.o ParticleDbg.o
pcl : $(PCLOBJ)
	nvcc $(LFLAGS) -o pcl $(PCLOBJ) $(LIBS)
DbgMain.o	: DbgMain.c ParticleDbg.h
	nvcc $(CFLAGS) -c DbgMain.c -o DbgMain.o
ParticleDbg.o    : ParticleDbg.c ParticleDbg.h
	nvcc -x cu -g $(CUDAINC) -c ParticleDbg.c -o ParticleDbg.o
clean:
	rm *.o
Header
#ifndef __PCL_H__
#define __PCL_H__
#ifdef __cplusplus
   extern "C" {
#endif
struct ParticleType {
   double Pos[3];
   double Vel[3];
   double Frc[3];
long Npcl;
double PclMass, PclRadius;
long PclGeomTag;
struct ParticleType *Pcl;
struct ParticleType *CudaPcl;
void InitParticleSystem(double center[3]);
void ParticleSimStep(double dt);
#ifdef __cplusplus
   } /* extern "C" */
#endif
#endif /* __PCL_H__ */
CUDA Functions
#include <cuda.h>
#include <cuda_runtime.h>
#include <stdio.h>
#include "ParticleDbg.h"
#ifdef __cplusplus
   extern "C" {
#endif
size_t SizeOfPcl;
      struct ParticleType *P,*CudaPcl;
      cudaError_t err = cudaSuccess;
      cudaSetDevice(0);
      Npcl = 100;
      SizeOfPcl = Npcl*sizeof(struct ParticleType);
      Pcl = (struct ParticleType *) malloc(SizeOfPcl);
      err = cudaMalloc((void **)&CudaPcl,SizeOfPcl);
      printf("cudaSuccess = %i\n",(int) cudaSuccess);
      printf("err = %i\n",(int) err);
      printf("In Init: CudaPcl = %p\n",CudaPcl);
__global__ void CudaParticleEOM(struct ParticleType *CP,long Npcl)
      long Ip;
      struct ParticleType *P;
      Ip = blockDim.x*blockIdx.x + threadIdx.x;
      if (Ip < Npcl) {
         P = &CP[Ip];
         /* EOM would go here */
      printf("In SimStep: CudaPcl = %p\n",CudaPcl);
      cudaMemcpy(CudaPcl,Pcl,SizeOfPcl,cudaMemcpyHostToDevice);
      int ThreadsPerBlock = 1;
      int BlocksPerGrid = (Npcl+ThreadsPerBlock-1)/ThreadsPerBlock;
      CudaParticleEOM<<<BlocksPerGrid,ThreadsPerBlock>>>(CudaPcl,Npcl);
      cudaMemcpy(Pcl,CudaPcl,SizeOfPcl,cudaMemcpyDeviceToHost);
#ifdef __cplusplus
   } /* extern "C" */
#endif
Main
#include <stdio.h>
#ifdef __cplusplus
   extern "C" {
#endif
int main(int argc, char **argv)
      double center[3] = {1.0,2.0,3.0};
      InitParticleSystem(center);
      printf("Back in Main: CudaPcl = %p\n",CudaPcl);
      ParticleSimStep(0.1);
      return(0);
#ifdef __cplusplus
   } /* extern "C" */
#endif
Output
cudaSuccess = 0
err = 0
In Init: CudaPcl = 0x500b80000
Back in Main: CudaPcl = 0x0
In SimStep: CudaPcl = 0x0
So why does the CudaPcl pointer appear as null outside the function that
cudaMalloc’ed it?
Thanks,
-DwP
because you shouldn’t define global variables in a header file that gets included from several modules.
Define the variables once in the main program, and declare these as “extern” in a header file visible to other modules. This makes sure only one instance of the variable exists in the entire binary.
Christian
Okay, I get what you’re saying (to a limited extent, I’ll admit). So I modified the header and source as seen below. No change in the output though, so I think I have another underlying issue.
Here’s the modified header:
#ifndef __PCL_H__
#define __PCL_H__
#ifdef __cplusplus
   extern "C" {
#endif
   double Pos[3];
   double Vel[3];
   double Frc[3];
EXTERN long Npcl;
EXTERN double PclMass, PclRadius;
EXTERN long PclGeomTag;
EXTERN struct ParticleType *Pcl;
EXTERN struct ParticleType *CudaPcl;
#ifdef __cplusplus
   } /* extern "C" */
#endif
and the main file:
#include <stdio.h>
#define EXTERN
#undef EXTERN
#ifdef __cplusplus
   extern "C" {
#endif
      return(0);
#ifdef __cplusplus
   } /* extern "C" */
#endif
and the other (CUDA-containing) source file:
#include <cuda.h>
#include <stdio.h>
#define EXTERN extern
#undef EXTERN
#ifdef __cplusplus
   extern "C" {
#endif
size_t SizeOfPcl;
      cudaSetDevice(0);
      Npcl = 100;
      long Ip;
      if (Ip < Npcl) {
         P = &CP[Ip];
#ifdef __cplusplus
   } /* extern "C" */
#endif
and the disappointing output:
cudaSuccess = 0
err = 0
Did I do the EXTERN trick wrong? Or is something else going on?
Thanks,
-DwP
Never mind. Found the bug. Duplicate definition of CudaPcl. End thread.
extern is a C/C++ keyword and has to be lowercase.
