:rolleyes:
Hi I’m KiWook Son student of Hanyang university in Korea.
I study CUDA and programed by it
but…
When using cudaMalloc,
int* a;
CUDA_SAFE_CALL( cudaMalloc( ( void ** )&a, sizeof( int ) ) );
This function go the _file.c → fprintf.c → exit()…
Finally The program exit it…
what’s the matter with it??
Plz help me…
:rolleyes:
but…
int* a;
Plz help me…
nothing wrong at all.
did you use any host function with “a”?
I agree with Quoc Vinh, the code looks OK.
What happens if you do int * a = 0; first?
Also, can you run the SDK sample programs, do they work OK?
Are you compiling in DEBUG mode? In debug mode, CUDA_SAFE_CALL exits on error, so I suggest running the program from the command line. This way, you will be able to read the error description.
Or just use
#define exit(x)
after including cutil.h to void any calls to exit().
