CudaMemCpy not working with out device emulation mode
Hi Folks,
Am a newbie to CUDA and am stuck while playing around with arrays.
All I am trying to do is, copy a single dimensional array from host to device and multiply each element of an array with some scalar value and return the results.
Eg:
Src : 5, 10, 20, 30, 40
Scalar Val : 10
Exp Result: 50, 100, 200, 300, 400
It works file when I compile in device emulation mode, but when that flag is turned off it just doesn’t. It always return zero’s
Before I go ahead I would like to post the code below
Kernel Code
__global__ void multiply(double* srcElems, double* resElems, int multiplier){
	int threadIndex = threadIdx.x;
	resElems[threadIndex] = srcElems[threadIndex] * multiplier;
	return;
C host
void checkCudaError(const char *msg)
	cudaError_t err = cudaGetLastError();
	if( 0 != err)
		printf( "\nCUDA error> %s %s.\n", msg, cudaGetErrorString( err) );
		exit(0);
double* multiplyArray(const double* srcArr, int multiplier, int size){
double* hostResElements = (double*)calloc(size, sizeof(double));
 double* deviceSrcElements;
 double* deviceResElements;
int memSize = size * sizeof(double);
 int index;
for(index=0; index<size; index++){
	printf("\nSrc [%d] : %f", index, srcArr[index]);
cudaMalloc((void**) &deviceSrcElements, memSize);
 checkCudaError("Memory Allocated to device src elements");
cudaMalloc((void**) &deviceResElements, memSize);
 checkCudaError("Memory Allocated to device target elements");
cudaMemcpy(deviceSrcElements, srcArr,  memSize, cudaMemcpyHostToDevice);
 checkCudaError("Memory copied from host src to device src");
multiply<<<1, size>>>(deviceSrcElements, deviceResElements, multiplier);
 checkCudaError("Kernel code invoked");
cudaMemcpy(hostResElements, deviceResElements, memSize, cudaMemcpyDeviceToHost);
 checkCudaError("Memory copied from device result to host result");
	printf("\nRes [%d] : %f", index, hostResElements[index]);
cudaFree(deviceSrcElements);
 checkCudaError("Cleaning up device src elements");
 cudaFree(deviceResElements);
 checkCudaError("Cleaning up device res elements");
return hostResElements;
int main(){
	double* srcArr = (double*) calloc ( 5, sizeof(double));
	int size = 5;
	int index;
		srcArr[index] =  size * index;
	double* result = multiplyArray(srcArr, 5, 5);
		printf ("Result in C [%d] : %f", index, result[index]);
	return 0;
Please let me know if I am doing anything wrong.
Thanx,
Katta
Oops!! I got to learn from one of the earlier posts that device code doesn’t support double.
So i changed all the types in my previous code to floats and it starts working fine.
Thnx,
Katta
