I am trying to work with a 2D Array
my firtst code works with memory from stack
the second code with memory allocated with calloc from heap results with a (bad pointer) error
both codes are equal, just allocation is different
is someone able to explain why this error happens?
[codebox]#include <stdio.h>
#include <cuda.h>
global void test(int *p, size_t pitch)
for (int r = 0; r < 5; ++r) {
int* row = (int*)((char*)p + r * pitch);
for (int c = 0; c < 5; ++c) {
row[c] = row[c] + 222;
main(){
const int size_x = 5; const int size_y = 5;
int *p, p_h[2], i, j;
size_t pitch;
for(i=0;i<size_y;i++){
for(j=0;j<size_x;j++){
p_h[1][i][j] = 2;
cudaMallocPitch((void**) &p, &pitch, size_x*sizeof(int), size_y);
cudaMemcpy2D(p,pitch,p_h[1],size_x*sizeof(int),size_x*sizeof
(int),size_y ,cudaMemcpyHostToDevice);
test<<<1,1>>>(p, pitch);
cudaMemcpy2D(p_h[1],size_x*sizeof(int),p,pitch,size_x*sizeof
(int),size_y,cudaMemcpyDeviceToHost);
printf("%d\t%d \n",i*5+j, p_h[1][i][j]);
system("PAUSE");
}[/codebox]
#include <cuda.h>
global void test(unsigned char *p, size_t pitch)
unsigned char* row = (unsigned char*)((char*)p + r * pitch);
main(){
unsigned char **p_h = (unsigned char**)(calloc(size_y,sizeof(unsigned char*)));
for (int j = 0; j < size_y; j++){
p_h[j] = (unsigned char*)(calloc(size_x,sizeof(unsigned char*)));
unsigned char *p;
size_t pitch;
for(int i=0;i<size_y;i++){
for(int j=0;j<size_x;j++){
p_h[i][j] = 2;
printf("%d\t%d \n",i*5+j, p_h[i][j]);
cudaMallocPitch((void**) &p, &pitch, size_x*sizeof(unsigned char), size_y);
cudaMemcpy2D(p,pitch,p_h,size_x*sizeof(unsigned char),size_x*sizeof(unsigned char),size_y ,cudaMemcpyHostToDevice);
cudaMemcpy2D(p_h,size_x*sizeof(unsigned char),p,pitch,size_x*sizeof(unsigned char),size_y,cudaMemcpyDeviceToHost);
//Output
system("PAUSE");
}[/codebox]
