Hey, I have a struct that looks something like this:
template<class T>
struct MyArray {
T* data;
int elementCount;
__host__ MyArray<T> UploadToDevice() {
Array3D<T> device = *this;
COMPUTE_SAFE(cudaMalloc((void**)&device.data, sizeof(T) * elementCount));
COMPUTE_SAFE(cudaMemcpy(device.data, data, sizeof(T) * elementCount, cudaMemcpyHostToDevice));
return device;
__host__ MyArray<T> UploadToHost() {
Array3D<T> host = *this;
COMPUTE_SAFE(cudaMalloc((void**)&host.data, sizeof(T) * elementCount));
COMPUTE_SAFE(cudaMemcpy(host.data, data, sizeof(T) * elementCount, cudaMemcpyDeviceToHost));
return host;
After initializing an instance of the struct I’m trying to copy it to the GPU and then back to host, but I get an Access violation reading location error
. This is what my upload and download code looks like:
__device__ MyArray<float> deviceArray;
void Test() {
MyArray<float> host; // zero initialized, element count was also correctly set
// Copy to the GPU
MyArray<float> device = host.UploadToDevice();
COMPUTE_SAFE(cudaMemcpyToSymbol(deviceArray, &device, sizeof(device)));
// Copy back from the GPU to host
host = device.UploadToHost();
COMPUTE_SAFE(cudaMemcpyFromSymbol(&host, deviceArray, sizeof(host), 0, cudaMemcpyDeviceToHost));
printf("%.2f", host.data[0]); // expected output is '0.00'
After the printf
statement gets called an Access violation reading location error
gets raised. Any ideas about what could be going wrong here? Thanks in advance :smile: .
Alright, so I’ve managed to do this with 1 instance of MyArray
, but whenever I try allocating another one I get an Invalid argument
error.
I have added two new utility methods to the MyArray
struct:
template <class S>
__host__ void UploadToDevice(Array3D<T>& device, const S& symbol) {
COMPUTE_SAFE(cudaMemcpyToSymbol(symbol, &device, sizeof(device)));
template <class S>
__host__ void UploadToHost(Array3D<T>& host, const S& symbol) {
COMPUTE_SAFE(cudaMemcpy(&host.data, data, sizeof(T) * elementCount, cudaMemcpyDeviceToHost));
COMPUTE_SAFE(cudaMemcpyFromSymbol(&host, symbol, sizeof(void*), 0, cudaMemcpyDeviceToHost));
I then use them to upload my data into the GPU:
__device__ MyArray<float> symbol1;
__device__ MyArray<float> symbol2;
void Test() {
MyArray<float> host1;
MyArray<float> host2;
MyArray<float> device1;
MyArray<float> device2;
// Initialize the host arrays...
// Upload to the GPU
host1.UploadToDevice(device1, symbol1);
host2.UploadToDevice(device2, symbol2);
// Upload back to the CPU
device1.UploadToHost(host1, symbol1);
device2.UploadToHost(host2, symbol2);
With this approach I can allocate a single instance of MyArray
, but as soon as I call a second upload call (host2.UploadToDevice(device2, symbol2)
) I get an error originating from the first line of the UploadToHost
method that tells me that I’m providing an invalid argument - Any ideas about what could be going wrong here? Thanks in advance.
I don’t wish to assemble my own testable example from your bits and pieces. If you want to provide a short, complete example that I can copy, paste, compile, and run, and observe the error, without having to add anything or change anything, I’ll take a look as time permits.
if that’s a problem for some reason, perhaps someone else will be able to spot something.
Absolutely, I’ll remember to provide an example of my problem next time, as the problem allows. For anyone else stumbling upon this topic - Robert’s answer here solved my issue.
