I try to see if the cudaMemcpyToArray working correctly using a simple code
sum = cplvSum2_32f_C1(d_temp3D, nElems, d_tempBuffer, 64) / nElems;
fprintf(stderr, " Debug value 01: %d %f \n",id, sum);
cudaMemcpyToArray(d_array3D_temp, 0, 0, d_temp3D, sizeMem , cudaMemcpyDeviceToDevice);
cudaMemset(d_temp3D, 0, sizeMem);
fprintf(stderr, " Debug value 02: %d %f \n",id, sum);
cudaMemcpyFromArray( d_temp3D, d_array3D_temp, 0, 0, sizeMem , cudaMemcpyDeviceToDevice);
fprintf(stderr, " Debug value 03: %d %f \n",id, sum);
In this code, i copy the contain of a device memory block to cudaArray, erase the memory contain, and read back the result from cudaArray to the memory block. I use the sum2 function that compute the total of square value from memory block.
In the case that everything run correctly the Debug value 01 and 03 will be the same while debug 02 will return 0.
I run with 1 GPU, the result is correct.
I run with 2 GPUs in parallel, some thing strange happen. On one GPUs the result is still correct. On the other,:
Debug value 01: 0 0.140667
Debug value 02: 0 0.000000
Debug value 03: 0 0.000000
There’s something incorrect with cudaMemcpyFrom/ToArray. Is that a bug.
The code i post here is exact the code i have inside my threads, and each thread run on one device using cudaSetDevice, all the array and memory block are allocated per thread (inside the thread function)
